Introducción
Follow this guide to remove the head of the India Mark III. You can then replace it or clean it, as necessary.
Herramientas
No se requieren herramientas.
Partes
No se requieren partes.
  1. Before performing any repairs, perform a water test on the pump by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters. Remove the hex head bolt from the top of the access door on the pump head.
    • Before performing any repairs, perform a water test on the pump by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
    • Remove the hex head bolt from the top of the access door on the pump head.
    • On reassembly, this bolt should be hand-tight.
  2. Pull the access door straight up off the pump head. Store the access door in a sanitary place to prevent contamination. Store the access door in a sanitary place to prevent contamination.
    • Pull the access door straight up off the pump head.
    • Store the access door in a sanitary place to prevent contamination.
  3. The access door has a tongue that fits into the base of the pump head. The access door makes a convenient tray to hold nuts and bolts during the disassembly.
    • The access door has a tongue that fits into the base of the pump head.
    • The access door makes a convenient tray to hold nuts and bolts during the disassembly.
  4. Place the spacer collar around the pump rod below the raised chain, with the beveled side down, and the flat side facing up. Place the spacer collar around the pump rod below the raised chain, with the beveled side down, and the flat side facing up. Place the spacer collar around the pump rod below the raised chain, with the beveled side down, and the flat side facing up.
    • Place the spacer collar around the pump rod below the raised chain, with the beveled side down, and the flat side facing up.
  5. The following procedure requires two people. If you attempt to do this alone, you risk injuring yourself and damaging the pump. Lift the pump handle until the base of the chain comes to rest on the spacer collar, and the chain is slack. Hold the handle in this position while the chain is being detached. Lift the pump handle until the base of the chain comes to rest on the spacer collar, and the chain is slack. Hold the handle in this position while the chain is being detached.
    • The following procedure requires two people. If you attempt to do this alone, you risk injuring yourself and damaging the pump.
    • Lift the pump handle until the base of the chain comes to rest on the spacer collar, and the chain is slack. Hold the handle in this position while the chain is being detached.
  6. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  7. Using the two access holes, place an angled socket wrench on the bolt and nut attaching the chain to the pump handle. Using the two access holes, place an angled socket wrench on the bolt and nut attaching the chain to the pump handle. Using the two access holes, place an angled socket wrench on the bolt and nut attaching the chain to the pump handle.
    • Using the two access holes, place an angled socket wrench on the bolt and nut attaching the chain to the pump handle.
  8. Hold the wrench on the bolt stationary. Loosen the nut. Loosen the nut.
    • Hold the wrench on the bolt stationary.
    • Loosen the nut.
  9. Remove the nut from the chain bolt. Remove the nut from the chain bolt. Remove the nut from the chain bolt.
    • Remove the nut from the chain bolt.
  10. Remove the washer from the chain bolt. Remove the washer from the chain bolt.
    • Remove the washer from the chain bolt.
  11. Remove the chain bolt. Remove the chain bolt.
    • Remove the chain bolt.
  12. Pull the top of the chain straight off of the pump handle. Pull the top of the chain straight off of the pump handle. Pull the top of the chain straight off of the pump handle.
    • Pull the top of the chain straight off of the pump handle.
  13. Remove the two bolts from the handle side of the pump head. Use one wrench on the bolt and another on the nut beneath. Hold the bolt stationary and loosen the nut. Use one wrench on the bolt and another on the nut beneath. Hold the bolt stationary and loosen the nut.
    • Remove the two bolts from the handle side of the pump head.
    • Use one wrench on the bolt and another on the nut beneath. Hold the bolt stationary and loosen the nut.
  14. Remove the two bolts and nuts from the handle side. Remove the two bolts and nuts from the handle side. Remove the two bolts and nuts from the handle side.
    • Remove the two bolts and nuts from the handle side.
  15. After removing the two handle side bolts, have your partner support the weight of the handle. Remove the two remaining bolts in the same fashion.
    • After removing the two handle side bolts, have your partner support the weight of the handle.
    • Remove the two remaining bolts in the same fashion.
  16. Lift and remove the pump head from the pump. Store the pump head in a sanitary place, preferably above ground, to prevent contamination. Store the pump head in a sanitary place, preferably above ground, to prevent contamination.
    • Lift and remove the pump head from the pump.
    • Store the pump head in a sanitary place, preferably above ground, to prevent contamination.
Conclusión
Equipo
iFixit Miembro de iFixit
Community
109 Miembros
7,722 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 96
