Saltar al contenido principal
InFocus Screenplay 4805 Lens Replacement
Qué necesitas
  1. InFocus Screenplay 4805 Lens Replacement, Top Panel: paso 1, imagen 1 de 3 InFocus Screenplay 4805 Lens Replacement, Top Panel: paso 1, imagen 2 de 3 InFocus Screenplay 4805 Lens Replacement, Top Panel: paso 1, imagen 3 de 3
    • Flip the projector on its back.
    • Use the Phillips #2 screwdriver to remove the (4) four 2 cm gold screws.
    • Use the Phillips #2 screwdriver to remove the (3) three 1 cm silver screws.
  2. InFocus Screenplay 4805 Lens Replacement: paso 2, imagen 1 de 2 InFocus Screenplay 4805 Lens Replacement: paso 2, imagen 2 de 2
    • Turn the projector, facing the back cable board towards you.
    • Using the Phillips #0 screwdriver, remove the (3) three 1.0 cm silver screws on the back panel.
    • Gently take off back cable panel.
  3. InFocus Screenplay 4805 Lens Replacement: paso 3, imagen 1 de 3 InFocus Screenplay 4805 Lens Replacement: paso 3, imagen 2 de 3 InFocus Screenplay 4805 Lens Replacement: paso 3, imagen 3 de 3
    • Turn the projector so the front side with the lens is facing you.
    • Gently pry the both of the grey lens rings using the metal spudger.
  4. InFocus Screenplay 4805 Lens Replacement: paso 4, imagen 1 de 1
    • Now that the screws have been removed, proceed with the removal of the outer panel.
    • Gently remove the front lens panel.
    • Be forewarned, the panel will resist. Be careful not to break the lens.
  5. InFocus Screenplay 4805 Lens Replacement: paso 5, imagen 1 de 1
    • Being careful not to pull the wires inside the projector, gently lift the top panel off the projector.
    • Rest the lid behind the projector so the insides are exposed and undamaged.
  6. InFocus Screenplay 4805 Lens Replacement, Lens: paso 6, imagen 1 de 3 InFocus Screenplay 4805 Lens Replacement, Lens: paso 6, imagen 2 de 3 InFocus Screenplay 4805 Lens Replacement, Lens: paso 6, imagen 3 de 3
    • Using the Phillips #1 screwdriver, remove the (3) three 1cm black screws on the face of the lens.
    • Gently pull out the lens.
Conclusión
To reassemble the device, follow these instructions in reverse order.
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 3
Todo El Tiempo: 658
