Saltar al contenido principal
InFocus LP540 Projector Speakers Replacement
Qué necesitas
  1. InFocus LP540 Projector Speakers Replacement, Speakers: paso 1, imagen 1 de 3 InFocus LP540 Projector Speakers Replacement, Speakers: paso 1, imagen 2 de 3 InFocus LP540 Projector Speakers Replacement, Speakers: paso 1, imagen 3 de 3
    • Flip the projector right-side up and turn it so the backports face you.
    • Remove the 7mm metallic hex screws using the flat-head screwdriver.
    • Remove the two black 10mm screws using the T10 Torx screwdriver head. The screws are located at the center of the back panel.
  2. InFocus LP540 Projector Speakers Replacement: paso 2, imagen 1 de 2 InFocus LP540 Projector Speakers Replacement: paso 2, imagen 2 de 2
    • Remove the two 77mm screws that are located nearest to the back panel ports. Use the T10 Torx screwdriver head.
    • Remove the two 10mm screws located near the lens side with the T10 Torx screwdriver head.
    • Flip the projector back over.
    • Then, cautiously proceed to lift the main lid to avoid ripping the electrical strips.
  3. InFocus LP540 Projector Speakers Replacement: paso 3, imagen 1 de 2 InFocus LP540 Projector Speakers Replacement: paso 3, imagen 2 de 2
    • Unplug the speaker wire from the circuit board by squeezing the sides and pulling.
    • Pull on the brown tabs located at the sides of the white plastic ribbon holder and pull the ribbon out.
  4. InFocus LP540 Projector Speakers Replacement: paso 4, imagen 1 de 3 InFocus LP540 Projector Speakers Replacement: paso 4, imagen 2 de 3 InFocus LP540 Projector Speakers Replacement: paso 4, imagen 3 de 3
    • Place the top shell of the projector down.
    • Remove the speaker wires from the white tabs.
    • Use the Phillips 0 screwdriver to remove the four 5.5 mm screws.
    • Carefully lift the speakers to remove them.
Conclusión
Reassembly: Close the speaker compartment and replace the light cover. Screw it back into place to secure all parts.
Jorge L Navarro
Miembro Desde 01/22/14
533 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 13-17, Regan Winter 2014 Miembro de Cal Poly, Team 13-17, Regan Winter 2014
CPSU-REGAN-W14S13G17
6 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 552
