Saltar al contenido principal
InFocus LP540 Projector Main Fans Replacement
Qué necesitas
  1. InFocus LP540 Projector Main Fans Replacement, Main Board: paso 1, imagen 1 de 3 InFocus LP540 Projector Main Fans Replacement, Main Board: paso 1, imagen 2 de 3 InFocus LP540 Projector Main Fans Replacement, Main Board: paso 1, imagen 3 de 3
    • Flip the projector right-side up and turn it so that the back ports are facing you.
    • Remove the 7 mm metallic screws using the flat-head screwdriver.
    • Using the T10 Torx screwdriver, remove the two black 10 mm screws located at the center of the back panel.
  2. InFocus LP540 Projector Main Fans Replacement: paso 2, imagen 1 de 2 InFocus LP540 Projector Main Fans Replacement: paso 2, imagen 2 de 2
    • Flip the projector over.
    • Use the T10 Torx screwdriver head to remove the two 77mm screws located nearest to the back panel ports.
    • Remove the two 10mm screws located near the lens side with the T10 Torx screwdriver head.
    • Flip the projector back over.
    • Lift up the main lid cautiously to avoid ripping the electrical ribbons.
  3. InFocus LP540 Projector Main Fans Replacement: paso 3, imagen 1 de 3 InFocus LP540 Projector Main Fans Replacement: paso 3, imagen 2 de 3 InFocus LP540 Projector Main Fans Replacement: paso 3, imagen 3 de 3
    • Unplug the speaker wire from the circuit board by simultaneously squeezing the sides and pulling.
    • Pull on the brown tabs located at the sides of the white plastic ribbon holder and pull the ribbon out.
    • Remove the top cover.
  4. InFocus LP540 Projector Main Fans Replacement: paso 4, imagen 1 de 2 InFocus LP540 Projector Main Fans Replacement: paso 4, imagen 2 de 2
    • Hold down the release tabs to remove the cables from the white tabs.
  5. InFocus LP540 Projector Main Fans Replacement: paso 5, imagen 1 de 3 InFocus LP540 Projector Main Fans Replacement: paso 5, imagen 2 de 3 InFocus LP540 Projector Main Fans Replacement: paso 5, imagen 3 de 3
    • Use the T10 Torx screwdriver to remove the five 5mm screws located throughout the motherboard.
    • Pull up the five metal tabs located at the rear of the projector.
    • Do not pull up on the metal tabs too hard or too fast because they can break easily.
  6. InFocus LP540 Projector Main Fans Replacement: paso 6, imagen 1 de 3 InFocus LP540 Projector Main Fans Replacement: paso 6, imagen 2 de 3 InFocus LP540 Projector Main Fans Replacement: paso 6, imagen 3 de 3
    • Remove the three gold ribbons by flipping up the black taps that hold the ribbon in place.
    • Pull the ribbons out carefully and place them under the main board.
    • Carefully lift the entire main board up.
  7. InFocus LP540 Projector Main Fans Replacement, Main Fans: paso 7, imagen 1 de 2 InFocus LP540 Projector Main Fans Replacement, Main Fans: paso 7, imagen 2 de 2
    • Once the main board has been removed, carefully lift the fans upward. Make sure no cables are tangled in the process.
Conclusión
Una persona más ha completado esta guía.
Jorge L Navarro
Miembro Desde 01/22/14
533 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 13-17, Regan Winter 2014 Miembro de Cal Poly, Team 13-17, Regan Winter 2014
CPSU-REGAN-W14S13G17
6 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 1,392
