Saltar al contenido principal
InFocus LP435Z Secondary Fan Replacement
Qué necesitas
  1. InFocus LP435Z Secondary Fan Replacement, External Shell: paso 1, imagen 1 de 2 InFocus LP435Z Secondary Fan Replacement, External Shell: paso 1, imagen 2 de 2
    • Place the projector on its back (buttons down) with the lens facing away from you.
    • Remove the two 84mm screws in the upper left and right corners of the projector using the Phillips #2 screwdriver.
    • Remove the remaining three 8.5mm screws using the Phillips #1 screwdriver.
  2. InFocus LP435Z Secondary Fan Replacement: paso 2, imagen 1 de 2 InFocus LP435Z Secondary Fan Replacement: paso 2, imagen 2 de 2
    • Use the plastic opening tools to push down the clips holding the lamp cover in place, and remove it.
    • There is no lamp assembly in the projector used in this guide, yours may appear different.
  3. InFocus LP435Z Secondary Fan Replacement: paso 3, imagen 1 de 2 InFocus LP435Z Secondary Fan Replacement: paso 3, imagen 2 de 2
    • Remove the two 8.5mm rear screws holding the rear case plate to the projector using the Phillips #1 screwdriver.
    • Pull the rear plate straight off and set it aside.
  4. InFocus LP435Z Secondary Fan Replacement: paso 4, imagen 1 de 3 InFocus LP435Z Secondary Fan Replacement: paso 4, imagen 2 de 3 InFocus LP435Z Secondary Fan Replacement: paso 4, imagen 3 de 3
    • Flip the projector over and turn around so that the lens faces you.
    • Twist the gray zoom adjustment ring clockwise and extend the lens all the way out, and then slide the zoom adjustment ring all the way towards the end of the lens as far as it will go.
    • Slide the front case plate towards the loosened zoom adjustment ring, until the top plate of the projector is freed from underneath the lip of the front case plate.
    • The front case plate will not come all the way off due to the zoom adjustment ring obstructing it. It will merely slide forward a bit.
  5. InFocus LP435Z Secondary Fan Replacement: paso 5, imagen 1 de 2 InFocus LP435Z Secondary Fan Replacement: paso 5, imagen 2 de 2
    • Lift away the top case plate and set it aside.
  6. InFocus LP435Z Secondary Fan Replacement, Secondary Fan: paso 6, imagen 1 de 2 InFocus LP435Z Secondary Fan Replacement, Secondary Fan: paso 6, imagen 2 de 2
    • Unplug the small ribbon cable connecting the DLP board to the motherboard. It is obstructing the secondary fan power cable.
    • Unplug the secondary fan's power cable from the motherboard.
  7. InFocus LP435Z Secondary Fan Replacement: paso 7, imagen 1 de 2 InFocus LP435Z Secondary Fan Replacement: paso 7, imagen 2 de 2
    • Remove the two Phillips #1 8.5mm screws holding the secondary fan in place.
    • The second screw is close to the bottom of the projector and may be difficult to see.
  8. InFocus LP435Z Secondary Fan Replacement: paso 8, imagen 1 de 1
    • Remove the secondary fan, by pulling straight up and out of projector.
Conclusión
2 personas más completaron esta guía.
Andrew Kennedy
Miembro Desde 01/29/13
186 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 20-3, Maness Winter 2013 Miembro de Cal Poly, Team 20-3, Maness Winter 2013
CPSU-MANESS-W13S20G3
Miembros de 4
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 494
