Saltar al contenido principal
InFocus IN3104 Speaker Replacement
Qué necesitas
  1. InFocus IN3104 Speaker Replacement, Top Cover: paso 1, imagen 1 de 3 InFocus IN3104 Speaker Replacement, Top Cover: paso 1, imagen 2 de 3 InFocus IN3104 Speaker Replacement, Top Cover: paso 1, imagen 3 de 3
    • Turn the projector so that the lens is facing you.
    • On the left side of the projector, there is a screw and a knob inside of the small grate.
    • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
    • Remove the service cover.
  2. InFocus IN3104 Speaker Replacement: paso 2, imagen 1 de 3 InFocus IN3104 Speaker Replacement: paso 2, imagen 2 de 3 InFocus IN3104 Speaker Replacement: paso 2, imagen 3 de 3
    • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
    • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
    • Remove the top cover.
    • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
  3. InFocus IN3104 Speaker Replacement, InFocus IN3104 Metal Cover Disassembly: paso 3, imagen 1 de 2 InFocus IN3104 Speaker Replacement, InFocus IN3104 Metal Cover Disassembly: paso 3, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove the nine 6 mm screws.
    • Lift up the metal cover and set it aside to reveal the motherboard.
  4. InFocus IN3104 Speaker Replacement: paso 4, imagen 1 de 3 InFocus IN3104 Speaker Replacement: paso 4, imagen 2 de 3 InFocus IN3104 Speaker Replacement: paso 4, imagen 3 de 3
    • Carefully pry up the black plastic locking bar of the ZIF connector on the motherboard with a plastic spudger.
    • Pull out the blue-tipped, white ribbon cable from the connector.
    • Remove the metal cover.
  5. InFocus IN3104 Speaker Replacement, Speaker: paso 5, imagen 1 de 2 InFocus IN3104 Speaker Replacement, Speaker: paso 5, imagen 2 de 2
    • Unplug the speaker wire that is located right behind the cooling fan.
    • Use a Phillips #1 screwdriver to remove the two 6 mm screws on the frame brackets.
  6. InFocus IN3104 Speaker Replacement: paso 6, imagen 1 de 3 InFocus IN3104 Speaker Replacement: paso 6, imagen 2 de 3 InFocus IN3104 Speaker Replacement: paso 6, imagen 3 de 3
    • Remove the side panel.
    • Use a Phillips #1 screwdriver to remove the two 6 mm screws.
    • Remove the speaker by pulling it straight out.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 206
