Introducción
This Metal Cover needs to be removed in order to replace most parts in the device.
Qué necesitas
Turn the projector so that the lens is facing you.
Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
Remove the service cover.
Use a Phillips #1 screwdriver to remove the nine 6 mm screws.
Lift up the metal cover and set it aside to reveal the motherboard.
Casi Terminas!
Conclusión
