Saltar al contenido principal
InFocus IN3104 Filter Replacement
Qué necesitas
  1. InFocus IN3104 Filter Replacement, Top Cover: paso 1, imagen 1 de 3 InFocus IN3104 Filter Replacement, Top Cover: paso 1, imagen 2 de 3 InFocus IN3104 Filter Replacement, Top Cover: paso 1, imagen 3 de 3
    • Turn the projector so that the lens is facing you.
    • On the left side of the projector, there is a screw and a knob inside of the small grate.
    • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
    • Remove the service cover.
  2. InFocus IN3104 Filter Replacement: paso 2, imagen 1 de 3 InFocus IN3104 Filter Replacement: paso 2, imagen 2 de 3 InFocus IN3104 Filter Replacement: paso 2, imagen 3 de 3
    • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
    • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
    • Remove the top cover.
    • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
  3. InFocus IN3104 Filter Replacement, Filter: paso 3, imagen 1 de 3 InFocus IN3104 Filter Replacement, Filter: paso 3, imagen 2 de 3 InFocus IN3104 Filter Replacement, Filter: paso 3, imagen 3 de 3
    • Use a Phillips # 1 screw driver to remove the 6 mm screw that secures the filter.
    • Once the screw is removed, remove the filter by pulling it straight out.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 307
