Saltar al contenido principal
Impuls Blender Electronic wire Replacement
Qué necesitas
  1. Impuls Blender Electronic wire Replacement, Electronic wire: paso 1, imagen 1 de 3 Impuls Blender Electronic wire Replacement, Electronic wire: paso 1, imagen 2 de 3 Impuls Blender Electronic wire Replacement, Electronic wire: paso 1, imagen 3 de 3
    • Here you see the Impuls blender
    • First, seperate the the blender jar from the bottom part by turning it and put it aside.
  2. Impuls Blender Electronic wire Replacement: paso 2, imagen 1 de 3 Impuls Blender Electronic wire Replacement: paso 2, imagen 2 de 3 Impuls Blender Electronic wire Replacement: paso 2, imagen 3 de 3
    • Turn the bottom part over and look at the bottom.
    • Take the rubber parts out of the 4 holes to reveal the screws.
    • Take the 4 screws out using a Phillips screwdriver.
  3. Impuls Blender Electronic wire Replacement: paso 3, imagen 1 de 3 Impuls Blender Electronic wire Replacement: paso 3, imagen 2 de 3 Impuls Blender Electronic wire Replacement: paso 3, imagen 3 de 3
    • Take the blue bottom part off the rest of the product to reveal the inside.
    • Unscrew the black piece to be able to slide the blue part away from the rest.
  4. Impuls Blender Electronic wire Replacement: paso 4, imagen 1 de 3 Impuls Blender Electronic wire Replacement: paso 4, imagen 2 de 3 Impuls Blender Electronic wire Replacement: paso 4, imagen 3 de 3
    • When you look to the inside, you see that there are two components; the buttons and the motor.
    • Unscrew the part that contains the buttons and take it off.
  5. Impuls Blender Electronic wire Replacement: paso 5, imagen 1 de 3 Impuls Blender Electronic wire Replacement: paso 5, imagen 2 de 3 Impuls Blender Electronic wire Replacement: paso 5, imagen 3 de 3
    • Take out the 3 screws that are deep inside.
    • Take off the blue part on top that was fixed with those screws.
    • Pull the black disc out by using the screwdriver as lever from multiple sides.
    • This will take some force, so do not be afraid it will break.
  6. Impuls Blender Electronic wire Replacement: paso 6, imagen 1 de 3 Impuls Blender Electronic wire Replacement: paso 6, imagen 2 de 3 Impuls Blender Electronic wire Replacement: paso 6, imagen 3 de 3
    • When you have taken off the black piece and revealed the 4 screws, unscrew them all.
    • Take out the motor part and the rest of the electronics.
  7. Impuls Blender Electronic wire Replacement: paso 7, imagen 1 de 3 Impuls Blender Electronic wire Replacement: paso 7, imagen 2 de 3 Impuls Blender Electronic wire Replacement: paso 7, imagen 3 de 3
    • Find the fraction in the wire.
    • Cut off the broken part
    • Strip both sides of the wire that have to be attached again.
  8. Impuls Blender Electronic wire Replacement: paso 8, imagen 1 de 2 Impuls Blender Electronic wire Replacement: paso 8, imagen 2 de 2
    • If you will use a shrink sleeve to cover the electronic wire, it has to be put on the wire first. Otherwise if electrical tape is used, this can be done afterwards.
    • Solder the two wires with a soldering iron.
    • Shrink the sleeve with a heater or put the electrical tape around the soldered wire.
Conclusión
To reassemble your device, follow the instructions in reverse order.
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 6
Ultimos 30 días: 35
Todo El Tiempo: 1,026
