Saltar al contenido principal
Impression i7 Front Camera Replacement
Qué necesitas
  1. Impression i7 Front Camera Replacement, Battery: paso 1, imagen 1 de 1
    • Wedge the plastic opening tool into the seam nearest to the screen surface and begin to pry off the back of the device.
  2. Impression i7 Front Camera Replacement: paso 2, imagen 1 de 1
    • Move the plastic opening tool along the perimeter of the device, loosening the entire back as you go.
  3. Impression i7 Front Camera Replacement: paso 3, imagen 1 de 1
    • After the entire perimeter has been pried, remove the back of the device.
    • Be careful not to disconnect the speaker and microphone cables attached to the back of the tablet.
  4. Impression i7 Front Camera Replacement: paso 4, imagen 1 de 2 Impression i7 Front Camera Replacement: paso 4, imagen 2 de 2
    • Remove the transparent, orange tape from the edge of the battery.
    • Pry the battery off, using the plastic opening tool.
  5. Impression i7 Front Camera Replacement: paso 5, imagen 1 de 1
    • Desolder the positive and negative leads.
  6. Impression i7 Front Camera Replacement: paso 6, imagen 1 de 2 Impression i7 Front Camera Replacement: paso 6, imagen 2 de 2
    • Pull the battery away from the adhesive.
    • Peel the gray tape from the top of the battery.
  7. Impression i7 Front Camera Replacement, Front Camera: paso 7, imagen 1 de 1
    • Gently pull the front camera connection out of its socket.
  8. Impression i7 Front Camera Replacement: paso 8, imagen 1 de 1
    • Lift the camera unit from its housing. The unit should come out with minimal force.
Conclusión
Cole Beaver
Miembro Desde 11/05/18
390 Reputación
3 Guías creadas
Equipo
IUPUI, Team S1-G5, Baechle Fall 2018 Miembro de IUPUI, Team S1-G5, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G5
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 94
