Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y Herramientas
Introducción
This guide will show you how to replace the battery in your Impression i7. This guide should be used whenever the battery in your device isn't performing as originally intended by the manufacturer.
Partes
No se especificaron partes.
  1. Wedge the plastic opening tool into the seam nearest to the screen surface and begin to pry off the back of the device.
    • Wedge the plastic opening tool into the seam nearest to the screen surface and begin to pry off the back of the device.
  2. Move the plastic opening tool along the perimeter of the device, loosening the entire back as you go.
    • Move the plastic opening tool along the perimeter of the device, loosening the entire back as you go.
  3. After the entire perimeter has been pried, remove the back of the device.
    • After the entire perimeter has been pried, remove the back of the device.
    • Be careful not to disconnect the speaker and microphone cables attached to the back of the tablet.
  4. Remove the transparent, orange tape from the edge of the battery. Pry the battery off, using the plastic opening tool.
    • Remove the transparent, orange tape from the edge of the battery.
    • Pry the battery off, using the plastic opening tool.
  5. Desolder the positive and negative leads.
    • Desolder the positive and negative leads.
  6. Pull the battery away from the adhesive. Peel the gray tape from the top of the battery.
    • Pull the battery away from the adhesive.
    • Peel the gray tape from the top of the battery.
Conclusión
Cole Beaver
Miembro Desde 05/11/18
363 Reputación
3 Guías creadas
Equipo
IUPUI, Team S1-G5, Baechle Fall 2018 Miembro de IUPUI, Team S1-G5, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G5
3 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 72
