Saltar al contenido principal
Imation Superdisk USB Drive Plastic Housing Replacement
Qué necesitas
  1. Imation Superdisk USB Drive Plastic Housing Replacement, Plastic Housing: paso 1, imagen 1 de 2 Imation Superdisk USB Drive Plastic Housing Replacement, Plastic Housing: paso 1, imagen 2 de 2
    • Flip the device over so the bottom is facing up.
    • You will know it is the bottom because there will be six silver screws visible.
  2. Imation Superdisk USB Drive Plastic Housing Replacement: paso 2, imagen 1 de 2 Imation Superdisk USB Drive Plastic Housing Replacement: paso 2, imagen 2 de 2
    • Remove the USB converter device by gently pulling it out.
    • Do not pull the converter device out by the cord.
  3. Imation Superdisk USB Drive Plastic Housing Replacement: paso 3, imagen 1 de 2 Imation Superdisk USB Drive Plastic Housing Replacement: paso 3, imagen 2 de 2
    • Remove the six silver screws using a small Phillips head screwdriver.
  4. Imation Superdisk USB Drive Plastic Housing Replacement: paso 4, imagen 1 de 2 Imation Superdisk USB Drive Plastic Housing Replacement: paso 4, imagen 2 de 2
    • Slide the bottom plastic panel of the shell down so it is free of the end cap and the top panel.
    • Lift panel free of device.
  5. Imation Superdisk USB Drive Plastic Housing Replacement: paso 5, imagen 1 de 2 Imation Superdisk USB Drive Plastic Housing Replacement: paso 5, imagen 2 de 2
    • Remove the plastic end cap by sliding it forward, freeing from the rest of the device.
    • You can identify the end cap by noting the label "SuperDisk Drive" above where you would insert a floppy disk.
  6. Imation Superdisk USB Drive Plastic Housing Replacement: paso 6, imagen 1 de 2 Imation Superdisk USB Drive Plastic Housing Replacement: paso 6, imagen 2 de 2
    • Slide the metal housing out of the plastic shell.
Conclusión
Una persona más ha completado esta guía.
Caitlin Horwatt
Miembro Desde 02/11/14
137 Reputación
2 Guías creadas
Equipo
Ohio State, Team 1-2, Buehl Spring 2014 Miembro de Ohio State, Team 1-2, Buehl Spring 2014
OSU-BUEHL-S14S1G2
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 830
