Qué necesitas
Flip the device over so the bottom is facing up.
You will know it is the bottom because there will be six silver screws visible.
Flip the disk drive over so the the plug on the daughter board is visible.
Place a plastic spudger in between the disk drive and its metal casing. Use the spudger as a lever the until the metal casing detaches from the disk drive.
Una persona más ha completado esta guía.
Un comentario
Does anyone know if the MAC USB version works on modern PCs?
