Saltar al contenido principal
IdeaPad Yoga 13 Charging Port Replacement
Qué necesitas
  1. IdeaPad Yoga 13 Charging Port Replacement, Charging Port: paso 1, imagen 1 de 1
    • Remove all ten screws using the T4 Torx screwdriver.
    • Remove the back cover from the device.
  2. IdeaPad Yoga 13 Charging Port Replacement: paso 2, imagen 1 de 2 IdeaPad Yoga 13 Charging Port Replacement: paso 2, imagen 2 de 2
    • Use the blue opening tool to further separate the keyboard bezel.
    • Carefully apply pressure to the keyboard. It should easily pop out.
  3. IdeaPad Yoga 13 Charging Port Replacement: paso 3, imagen 1 de 1
    • To remove the keyboard bezel, unscrew and remove the five screws using the Phillips #0 screwdriver.
  4. IdeaPad Yoga 13 Charging Port Replacement: paso 4, imagen 1 de 2 IdeaPad Yoga 13 Charging Port Replacement: paso 4, imagen 2 de 2
    • Unplug the connections from the motherboard.
    • There is a different connection for the mouse and keyboard.
  5. IdeaPad Yoga 13 Charging Port Replacement: paso 5, imagen 1 de 1
    • Remove the outer bezel to reveal the entire internal layout of the computer.
    • Motherboard and other internal components are now exposed.
  6. IdeaPad Yoga 13 Charging Port Replacement: paso 6, imagen 1 de 3 IdeaPad Yoga 13 Charging Port Replacement: paso 6, imagen 2 de 3 IdeaPad Yoga 13 Charging Port Replacement: paso 6, imagen 3 de 3
    • Remove charging port by prying out the yellow port from the computer chassis.
    • Note the route of the cable for re-installation of the replacement.
Conclusión
2 personas más completaron esta guía.
Equipo
IUPUI, Team S1-G2, Harley Spring 2019 Miembro de IUPUI, Team S1-G2, Harley Spring 2019
IUPUI-HARLEY-S19S1G2
3 Miembros
2 Guías creadas
Un comentario
do you have the schematic of the board?
Jorge Herrera - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 22
Todo El Tiempo: 1,625
