Saltar al contenido principal
Ibanez Guitar Neck and Bridge Pickups Replacement
Qué necesitas
  1. Ibanez Guitar Neck and Bridge Pickups Replacement, Neck and Bridge Pickups: paso 1, imagen 1 de 2 Ibanez Guitar Neck and Bridge Pickups Replacement, Neck and Bridge Pickups: paso 1, imagen 2 de 2
    • Turn the tuning pegs in a counterclockwise direction to loosen the strings.
    • Pull the strings from the tuning pegs and thread them out the back of the guitar.
  2. Ibanez Guitar Neck and Bridge Pickups Replacement: paso 2, imagen 1 de 1
    • Use a soft cloth or a guitar cleaning kit to wipe down the body, neck, and fretboard.
  3. Ibanez Guitar Neck and Bridge Pickups Replacement: paso 3, imagen 1 de 2 Ibanez Guitar Neck and Bridge Pickups Replacement: paso 3, imagen 2 de 2
    • Use the screwdriver to loosen each screw on the pickguard.
    • Remove knobs and pickup selector switch.
    • These knobs can be very tough to remove. If you feel like you may damage them by forcing them off, just leave them on.
  4. Ibanez Guitar Neck and Bridge Pickups Replacement: paso 4, imagen 1 de 1
    • Remove the old pickups from the guitar body.
  5. Ibanez Guitar Neck and Bridge Pickups Replacement: paso 5, imagen 1 de 2 Ibanez Guitar Neck and Bridge Pickups Replacement: paso 5, imagen 2 de 2
    • Desolder connections from both red and green wire bundles.
    • There should be three separate wires per bundle that need to be individually removed.
    • For soldering help, visit this guide.
  6. Ibanez Guitar Neck and Bridge Pickups Replacement: paso 6, imagen 1 de 2 Ibanez Guitar Neck and Bridge Pickups Replacement: paso 6, imagen 2 de 2
    • Solder the new pickup wires to your control board.
    • Place your new pickups in the guitar body.
    • We highly recommend having a manual pertaining to your specific pickups. It will show you where each specific wire needs to be attached.
  7. Ibanez Guitar Neck and Bridge Pickups Replacement: paso 7, imagen 1 de 1
    • Use the screwdriver to reinstall pickguard screws.
    • Re-attach pickup selector and knobs.
    • Not all screw locations are visible in the image. Make sure to use all of them.
  8. Ibanez Guitar Neck and Bridge Pickups Replacement: paso 8, imagen 1 de 2 Ibanez Guitar Neck and Bridge Pickups Replacement: paso 8, imagen 2 de 2
    • Thread your new strings through the back of the guitar, up to the tuning pegs, and tighten the strings.
    • Use the wire cutters to trim excess string from the ends.
Linea de Meta
Joe Torres
Miembro Desde 02/21/23
157 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 8
Ultimos 30 días: 56
Todo El Tiempo: 641
