Saltar al contenido principal
Ibanez Bass Guitar String Replacement
Qué necesitas
  1. Ibanez Bass Guitar String Replacement, String: paso 1, imagen 1 de 2 Ibanez Bass Guitar String Replacement, String: paso 1, imagen 2 de 2
    • In this picture you will find the headstock of the bass.
    • Turning the tuning peg counter clockwise to loosen the string.
    • Here you may use a drill as an easy and fast alternative.
  2. Ibanez Bass Guitar String Replacement: paso 2, imagen 1 de 2 Ibanez Bass Guitar String Replacement: paso 2, imagen 2 de 2
    • Pull the string from the bottom of the bass from the guitar's bridge.
  3. Ibanez Bass Guitar String Replacement: paso 3, imagen 1 de 2 Ibanez Bass Guitar String Replacement: paso 3, imagen 2 de 2
    • Pull the string through the guitar's bridge and upward though the headstock of the guitar.
  4. Ibanez Bass Guitar String Replacement: paso 4, imagen 1 de 2 Ibanez Bass Guitar String Replacement: paso 4, imagen 2 de 2
    • Wrap the new string around the corresponding tuning peg.
  5. Ibanez Bass Guitar String Replacement: paso 5, imagen 1 de 2 Ibanez Bass Guitar String Replacement: paso 5, imagen 2 de 2
    • Tighten the string by turning the tuning peg.
  6. Ibanez Bass Guitar String Replacement: paso 6, imagen 1 de 2 Ibanez Bass Guitar String Replacement: paso 6, imagen 2 de 2
    • Repeat steps 2 through 5 until you have changed all four strings.
Conclusión
After you remove the first string, you will reassemble and continue the process until you have changed all four strings.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 63
Todo El Tiempo: 206
