Saltar al contenido principal
IQ America VD-8810L Motherboard Replacement
Qué necesitas
  1. IQ America VD-8810L Motherboard Replacement, Motherboard: paso 1, imagen 1 de 3 IQ America VD-8810L Motherboard Replacement, Motherboard: paso 1, imagen 2 de 3 IQ America VD-8810L Motherboard Replacement, Motherboard: paso 1, imagen 3 de 3
    • Wedge the spudger into the slot of the panel on the bottom of the device.
    • Rotate out the panel to reveal the screw holding the device together.
  2. IQ America VD-8810L Motherboard Replacement: paso 2, imagen 1 de 2 IQ America VD-8810L Motherboard Replacement: paso 2, imagen 2 de 2
    • Use the Phillips head screwdriver to remove the screw.
    • Separate the Top and bottom halves of the device.
  3. IQ America VD-8810L Motherboard Replacement: paso 3, imagen 1 de 3 IQ America VD-8810L Motherboard Replacement: paso 3, imagen 2 de 3 IQ America VD-8810L Motherboard Replacement: paso 3, imagen 3 de 3
    • Remove batteries from the battery slot.
    • Unscrew the two Phillips head screws in the center of the battery slot.
    • Unscrew the remaining two screws at the bottom of the unit using the 3.0 triangle head screwdriver.
  4. IQ America VD-8810L Motherboard Replacement: paso 4, imagen 1 de 1
    • Use the spudger to separate the top and bottom halves of the screen.
  5. IQ America VD-8810L Motherboard Replacement: paso 5, imagen 1 de 1
    • Disconnect the wires from the green motherboard to the bottom half by pulling apart the connecting pins.
  6. IQ America VD-8810L Motherboard Replacement: paso 6, imagen 1 de 3 IQ America VD-8810L Motherboard Replacement: paso 6, imagen 2 de 3 IQ America VD-8810L Motherboard Replacement: paso 6, imagen 3 de 3
    • Unscrew all 3 Phillips head screws on the outside edges of the motherboard.
  7. IQ America VD-8810L Motherboard Replacement: paso 7, imagen 1 de 1
    • Carefully remove the microphone from the casing by pulling away from the device.
  8. IQ America VD-8810L Motherboard Replacement: paso 8, imagen 1 de 2 IQ America VD-8810L Motherboard Replacement: paso 8, imagen 2 de 2
    • Gently lift the motherboard from the casing to reveal the speaker.
    • Unscrew the two Phillips head screws that hold the speaker in place.
  9. IQ America VD-8810L Motherboard Replacement: paso 9, imagen 1 de 1
    • Refer to this guide to desolder the speaker from the motherboard.
Conclusión
Jackey Lau
Miembro Desde 10/17/17
301 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 238
