Saltar al contenido principal
ILVE Microwave Replacement Bulb Replacement
Qué necesitas
  1. ILVE Microwave  Replacement Bulb Replacement, Remove the microwave from cabinate: paso 1, imagen 1 de 1
    • Remove the brown plug.
    • The screw attaching the microwave is below
  2. ILVE Microwave  Replacement Bulb Replacement, Remove the outer case: paso 2, imagen 1 de 2 ILVE Microwave  Replacement Bulb Replacement, Remove the outer case: paso 2, imagen 2 de 2
    • Remove the cross point screws from the outer case back
    • One screw has a tamper proof head so cut a slot it in and unscrew with a flat head screw driver.
    • Take caution to ensure that no metal shards fall inside the microwave. You may want to tape over the holes or wipe the area off with a damp cloth or paper towel once finished.
  3. ILVE Microwave  Replacement Bulb Replacement, Remove the bulb socket: paso 3, imagen 1 de 1
    • The socket is on top right side of the microwave
    • Remove the plugs
    • Bend up the metal clips, and pull out the socket
  4. ILVE Microwave  Replacement Bulb Replacement, Remove the bulb from the socket: paso 4, imagen 1 de 2 ILVE Microwave  Replacement Bulb Replacement, Remove the bulb from the socket: paso 4, imagen 2 de 2
    • Remove the white glue (or sealer) that's around the bulb screw using a small screw driver.
    • The glue goes all the way down the thread so remove as much as you can see.
    • Use leather gloves to unscrew incase the bulb breaks. It need quite a lot of force so make really sure you've got every bit a glue out.
  5. ILVE Microwave  Replacement Bulb Replacement, Re assmeble: paso 5, imagen 1 de 1
    • When you re assemble the outer case make sure the tabs on the front go either side of the front.
Conclusión
3 personas más completaron esta guía.
Martin Hampton
Miembro Desde 02/13/16
1,308 Reputación
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 61
Todo El Tiempo: 2,951
