Saltar al contenido principal
IBM Thinkpad T61 Trackpad Replacement
Qué necesitas
  1. IBM Thinkpad T61 Trackpad Replacement, Trackpad: paso 1, imagen 1 de 1
    • Flip your computer over and remove the four indicated screws with the Phillips #1 screwdriver.
  2. IBM Thinkpad T61 Trackpad Replacement: paso 2, imagen 1 de 1
    • With the screws removed, the trackpad panel should lift as shown. Gently lift so the inside is visible.
  3. IBM Thinkpad T61 Trackpad Replacement: paso 3, imagen 1 de 2 IBM Thinkpad T61 Trackpad Replacement: paso 3, imagen 2 de 2
    • Gently remove the white plug to disconnect the trackpad panel from the bottom of the computer.
    • Use the screwdriver to remove the four screws from the trackpad. Two of the screws are located just under the plastic.
  4. IBM Thinkpad T61 Trackpad Replacement: paso 4, imagen 1 de 3 IBM Thinkpad T61 Trackpad Replacement: paso 4, imagen 2 de 3 IBM Thinkpad T61 Trackpad Replacement: paso 4, imagen 3 de 3
    • Separate the trackpad with the bottom mouse buttons from the trackpad panel.
  5. IBM Thinkpad T61 Trackpad Replacement: paso 5, imagen 1 de 1
    • Align the new trackpad so the screw holes line up with their insertion points. Replace the screws with the screwdriver.
  6. IBM Thinkpad T61 Trackpad Replacement: paso 6, imagen 1 de 1
    • Reinsert the white plug.
  7. IBM Thinkpad T61 Trackpad Replacement: paso 7, imagen 1 de 2 IBM Thinkpad T61 Trackpad Replacement: paso 7, imagen 2 de 2
    • Replace the trackpad panel.
    • Use the screwdriver to replace the screws, refastening the trackpad panel to the computer.
Conclusión
Replace the battery and plug in your computer. Test out your new trackpad!
6 personas más completaron esta guía.
Raymond Lawton
Miembro Desde 03/12/14
245 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 21
Todo El Tiempo: 1,784
