Saltar al contenido principal
IBM Thinkpad T61 RAM Replacement
Qué necesitas
  1. IBM Thinkpad T61 RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Ensure the laptop has been properly shut down and unplugged.
    • Turn the computer over so that you can see the battery release tab located near the top of the Thinkpad.
  2. IBM Thinkpad T61 RAM Replacement: paso 2, imagen 1 de 1
    • Use your finger to slide the release tab to the unlocked symbol.
  3. IBM Thinkpad T61 RAM Replacement: paso 3, imagen 1 de 3 IBM Thinkpad T61 RAM Replacement: paso 3, imagen 2 de 3 IBM Thinkpad T61 RAM Replacement: paso 3, imagen 3 de 3
    • Hold the tab in the unlocked position and push the battery away from the computer to remove it.
  4. IBM Thinkpad T61 RAM Replacement: paso 4, imagen 1 de 1
    • Slide the new battery in until it clicks.
    • Ensure that the release tab is in the locked position.
  5. IBM Thinkpad T61 RAM Replacement, RAM: paso 5, imagen 1 de 1
    • Using a #0 Phillips screwdriver, remove four 17.0mm screws on the back of the computer.
    • These screws have a RAM symbol next to them.
  6. IBM Thinkpad T61 RAM Replacement: paso 6, imagen 1 de 1
    • Flip back over and open the laptop.
    • Lift up on the inside front panel just below the edge of the keyboard.
  7. IBM Thinkpad T61 RAM Replacement: paso 7, imagen 1 de 1
    • The green rectangles under the front panel are the RAM.
  8. IBM Thinkpad T61 RAM Replacement: paso 8, imagen 1 de 3 IBM Thinkpad T61 RAM Replacement: paso 8, imagen 2 de 3 IBM Thinkpad T61 RAM Replacement: paso 8, imagen 3 de 3
    • Press out on the two tabs on either side of the ram at the same time.
    • The RAM will release and pop up at a 25 degree angle.
  9. IBM Thinkpad T61 RAM Replacement: paso 9, imagen 1 de 1
    • Pull the RAM away from the housing to remove.
Conclusión
15 personas más completaron esta guía.
Kyle
Miembro Desde 04/18/13
458 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 8-58, Johann Spring 2013 Miembro de Cal Poly, Team 8-58, Johann Spring 2013
CPSU-JOHANN-S13S8G58
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 14
Ultimos 30 días: 37
Todo El Tiempo: 9,016
