Saltar al contenido principal
IBM Thinkpad T61 Battery Replacement
  1. IBM Thinkpad T61 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Ensure the laptop has been properly shut down and unplugged.
    • Turn the computer over so that you can see the battery release tab located near the top of the Thinkpad.
  2. IBM Thinkpad T61 Battery Replacement: paso 2, imagen 1 de 1
    • Use your finger to slide the release tab to the unlocked symbol.
  3. IBM Thinkpad T61 Battery Replacement: paso 3, imagen 1 de 3 IBM Thinkpad T61 Battery Replacement: paso 3, imagen 2 de 3 IBM Thinkpad T61 Battery Replacement: paso 3, imagen 3 de 3
    • Hold the tab in the unlocked position and push the battery away from the computer to remove it.
  4. IBM Thinkpad T61 Battery Replacement: paso 4, imagen 1 de 1
    • Slide the new battery in until it clicks.
    • Ensure that the release tab is in the locked position.
Linea de Meta
4 personas más completaron esta guía.
Kyle
Miembro Desde 04/18/13
458 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 8-58, Johann Spring 2013 Miembro de Cal Poly, Team 8-58, Johann Spring 2013
CPSU-JOHANN-S13S8G58
4 Miembros
10 Guías creadas
Un comentario
Ibm t61 battery purchase
Afjal Ansari - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 18
Todo El Tiempo: 3,356
