Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
IBM Thinkpad T60 LCD Screen Replacement
Qué necesitas
  1. IBM Thinkpad T60 LCD Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the computer over to see the small tab on the battery located near the top of the Thinkpad.
    • Use your finger to slide the tab to the right to unlock the battery.
    Pregunta a FixBot
    Agregar Comentario
  2. IBM Thinkpad T60 LCD Screen Replacement: paso 2, imagen 1 de 2 IBM Thinkpad T60 LCD Screen Replacement: paso 2, imagen 2 de 2
    • Once the tab is in the unlocked position (far right), pull the battery outwards away from the Thinkpad.
    • The battery is now disconnected.
    Pregunta a FixBot
    Agregar Comentario
  3. IBM Thinkpad T60 LCD Screen Replacement, LCD Screen: paso 3, imagen 1 de 3 IBM Thinkpad T60 LCD Screen Replacement, LCD Screen: paso 3, imagen 2 de 3 IBM Thinkpad T60 LCD Screen Replacement, LCD Screen: paso 3, imagen 3 de 3
    • Open the laptop so that the screen is facing you.
    • Use a plastic opening tool to pry off the eight plastic screw covers around the display.
    • Note that there are screw covers on the sides (two on the left and one on the right).
    Pregunta a FixBot
    Agregar Comentario
  4. IBM Thinkpad T60 LCD Screen Replacement: paso 4, imagen 1 de 1
    • Use a #0 Phillips screwdriver to remove the eight 3.25 mm screws uncapped from the previous step.
    Pregunta a FixBot
    Agregar Comentario
  5. IBM Thinkpad T60 LCD Screen Replacement: paso 5, imagen 1 de 2 IBM Thinkpad T60 LCD Screen Replacement: paso 5, imagen 2 de 2
    • Carefully pry the plastic border away from the screen using the plastic opening tool.
    • Note that this step requires some force. There are plastic clips that help hold the border in place so do not worry about snapping sounds.
    Pregunta a FixBot
    Agregar Comentario
  6. IBM Thinkpad T60 LCD Screen Replacement: paso 6, imagen 1 de 1
    • Use your fingers to pry the screen out of its housing far enough to gain access to the ribbon cables and small screws holding the screen in place.
    Pregunta a FixBot
    Agregar Comentario
  7. IBM Thinkpad T60 LCD Screen Replacement: paso 7, imagen 1 de 1
    • At the top of the screen, detach the small white clip by pulling it towards you with your finger.
    Pregunta a FixBot
    Agregar Comentario
  8. IBM Thinkpad T60 LCD Screen Replacement: paso 8, imagen 1 de 2 IBM Thinkpad T60 LCD Screen Replacement: paso 8, imagen 2 de 2
    • Using a #0 Phillips screwdriver, remove the 4 mm screw.
    Pregunta a FixBot
    Agregar Comentario
  9. IBM Thinkpad T60 LCD Screen Replacement: paso 9, imagen 1 de 2 IBM Thinkpad T60 LCD Screen Replacement: paso 9, imagen 2 de 2
    • Using a #0 Phillips screwdriver, remove the four 3.25 mm screws
    • The other two screws are in the same position on the opposite side of the display.
    Pregunta a FixBot
    Agregar Comentario
  10. IBM Thinkpad T60 LCD Screen Replacement: paso 10, imagen 1 de 2 IBM Thinkpad T60 LCD Screen Replacement: paso 10, imagen 2 de 2
    • The screen should be free to move now. Let the display rest on the keyboard with the screen facing down.
    • Peel the tape off to expose the LCD connection.
    Pregunta a FixBot
    Agregar Comentario
  11. IBM Thinkpad T60 LCD Screen Replacement: paso 11, imagen 1 de 2 IBM Thinkpad T60 LCD Screen Replacement: paso 11, imagen 2 de 2
    • Turn the inverter over to expose the white clip.
    • Squeeze and pull the wires with your fingers to detach the white clip.
    Pregunta a FixBot
    Agregar Comentario
  12. IBM Thinkpad T60 LCD Screen Replacement: paso 12, imagen 1 de 1
    • Disconnect the video cable by pulling the grey flat wire. Now the screen is completely separate from the ThinkPad.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
6 personas más completaron esta guía.
Equipo
Cal Poly, Team 7-9, Maness Winter 2013 Miembro de Cal Poly, Team 7-9, Maness Winter 2013
CPSU-MANESS-W13S7G9
Miembros de 4
16 Guías creadas
1Guía Comentario
Thanks for the info! ☼
Stck Flw - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 13
Ultimos 30 días: 67
Todo El Tiempo: 13,815
