Saltar al contenido principal
IBM Thinkpad T60 Hard Drive Replacement
Qué necesitas
  1. IBM Thinkpad T60 Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Turn the Thinkpad over so you can see the back.
    • Locate this screw in the bottom left-hand corner.
  2. IBM Thinkpad T60 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Using a #0 Phillips screwdriver, remove the 17.0 mm screw.
  3. IBM Thinkpad T60 Hard Drive Replacement: paso 3, imagen 1 de 1
    • Carefully remove the plastic piece covering the hard drive port by pulling perpendicular to the side of the laptop.
  4. IBM Thinkpad T60 Hard Drive Replacement: paso 4, imagen 1 de 2 IBM Thinkpad T60 Hard Drive Replacement: paso 4, imagen 2 de 2
    • Use a small screwdriver to locate the black ribbon.
    • With the screwdriver, pull the black tab out of the slot.
  5. IBM Thinkpad T60 Hard Drive Replacement: paso 5, imagen 1 de 2 IBM Thinkpad T60 Hard Drive Replacement: paso 5, imagen 2 de 2
    • Pull gently on the black ribbon and the metal tray carrying the hard drive will slide out.
  6. IBM Thinkpad T60 Hard Drive Replacement: paso 6, imagen 1 de 1
    • Remove the black plastic coverings on either side of the hard drive.
    • There is not a hard drive in this example, but the process is the same regardless.
Conclusión
9 personas más completaron esta guía.
Equipo
Cal Poly, Team 7-9, Maness Winter 2013 Miembro de Cal Poly, Team 7-9, Maness Winter 2013
CPSU-MANESS-W13S7G9
Miembros de 4
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 16
Ultimos 30 días: 73
Todo El Tiempo: 11,079
