Saltar al contenido principal
IBM ThinkPad t43 RAM Replacement
Qué necesitas
  1. IBM ThinkPad t43 RAM Replacement, RAM: paso 1, imagen 1 de 3 IBM ThinkPad t43 RAM Replacement, RAM: paso 1, imagen 2 de 3 IBM ThinkPad t43 RAM Replacement, RAM: paso 1, imagen 3 de 3
    • To remove the cover, you will need to take out the single screw.
    • Unscrew until the cover comes off
    • Lift the cover from the edge and pull off
    • If the cover doesn't come right up and you have felt that you have unscrewed it, you can lift the cover and the screw will come off with it.
  2. IBM ThinkPad t43 RAM Replacement: paso 2, imagen 1 de 3 IBM ThinkPad t43 RAM Replacement: paso 2, imagen 2 de 3 IBM ThinkPad t43 RAM Replacement: paso 2, imagen 3 de 3
    • Place your hands on the clips and push on them outward until the RAM pops out
  3. IBM ThinkPad t43 RAM Replacement: paso 3, imagen 1 de 2 IBM ThinkPad t43 RAM Replacement: paso 3, imagen 2 de 2
    • Place hands on the RAM and pull towards yourself
    • For replacement, follow these steps in reverse order
    • Make sure that when you put in the ram that the short side is on the right
Conclusión
2 personas más completaron esta guía.
aLiX pIeRRe
Miembro Desde 03/19/18
855 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team S6-G4, Bernier Spring 2018 Miembro de UMass Dartmouth, Team S6-G4, Bernier Spring 2018
UMASSD-BERNIER-S18S6G4
Miembros de 4
10 Guías creadas
Un comentario
There are two (2) SODIM slots on the T43 - this shows the easiest slot to access. There is a second SODIM slot underneath the keyboard. You will need to remove the palm rest and keyboard to access the second SODIM slot. This is the SODIM slot that comes populated with the 512MB SODIM.
Note you can add a 2GB SODIM in one slot with the 512MB SODIM in the other for a maximum of 2.5GB.
IrishMASMS - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 39
Todo El Tiempo: 1,308
