Saltar al contenido principal
IBM ThinkPad X41 Keyboard Replacement
Qué necesitas
  1. IBM ThinkPad X41 Keyboard Replacement, Keyboard: paso 1, imagen 1 de 3 IBM ThinkPad X41 Keyboard Replacement, Keyboard: paso 1, imagen 2 de 3 IBM ThinkPad X41 Keyboard Replacement, Keyboard: paso 1, imagen 3 de 3
    • Slide outward to unlock and lift battery up to remove.
    • Remove battery before keyboard to avoid damage to battery.
  2. IBM ThinkPad X41 Keyboard Replacement: paso 2, imagen 1 de 1
    • With a Phillips PH000 to remove all six 6 mm screws identified for the keyboard as shown.
  3. IBM ThinkPad X41 Keyboard Replacement: paso 3, imagen 1 de 3 IBM ThinkPad X41 Keyboard Replacement: paso 3, imagen 2 de 3 IBM ThinkPad X41 Keyboard Replacement: paso 3, imagen 3 de 3
    • Flip the laptop over once more returning it to its upright position and open laptop .
  4. IBM ThinkPad X41 Keyboard Replacement: paso 4, imagen 1 de 2 IBM ThinkPad X41 Keyboard Replacement: paso 4, imagen 2 de 2
    • Using your left hand, place thumb on the upper part of the keyboard and place your other thumb on the bottom part of the keyboard.
    • Push firmly upward with both thumbs. This will detach keyboard from base.
    • Be cautious when lifting as there is an orange connection cable still attached to the bottom side.
  5. IBM ThinkPad X41 Keyboard Replacement: paso 5, imagen 1 de 2 IBM ThinkPad X41 Keyboard Replacement: paso 5, imagen 2 de 2
    • Detach the connection to the motherboard by first sliding it towards you, then pulling upward away from your body.
    • This step's directions are based on the angle shown .
  6. IBM ThinkPad X41 Keyboard Replacement: paso 6, imagen 1 de 1
    • Lift the entire keyboard off the laptop.
Conclusión
Una persona más ha completado esta guía.
Lisbeth Cisneros
Miembro Desde 09/12/16
131 Reputación
1 Guía escrita
Equipo
CSU Fullerton, Team 2-4, Bruce Fall 2016 Miembro de CSU Fullerton, Team 2-4, Bruce Fall 2016
CSUF-BRUCE-F16S2G4
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 19
Todo El Tiempo: 717
