Saltar al contenido principal
IBM ThinkPad T43 Screen Replacement
Qué necesitas
  1. IBM ThinkPad T43 Screen Replacement, Screen: paso 1, imagen 1 de 3 IBM ThinkPad T43 Screen Replacement, Screen: paso 1, imagen 2 de 3 IBM ThinkPad T43 Screen Replacement, Screen: paso 1, imagen 3 de 3
    • Locate the screws holding the screen cover in place.
    • There are 3 screws on the left side, 4 on the right, and 4 across the bottom of the screen.
  2. IBM ThinkPad T43 Screen Replacement: paso 2, imagen 1 de 3 IBM ThinkPad T43 Screen Replacement: paso 2, imagen 2 de 3 IBM ThinkPad T43 Screen Replacement: paso 2, imagen 3 de 3
    • Remove the covers by inserting plastic spudger in between the edge of the cover and laptop.
    • Remove screws by using the Phillips head #0
    • The covers are set in with an adhesive so they may pop off when removing them.
  3. IBM ThinkPad T43 Screen Replacement: paso 3, imagen 1 de 3 IBM ThinkPad T43 Screen Replacement: paso 3, imagen 2 de 3 IBM ThinkPad T43 Screen Replacement: paso 3, imagen 3 de 3
    • Insert the flat metal spudger into the edge of the screen cover and slowly pry open.
    • Slide the spudger along the edges and pry open to release the cover from the clips
    • While slide the spudger up the side of the cover, pinch the cover to help unhook the clips
    • Across the bottom of the screen there is an adhesive, so you will need to carefully pry of that part of the cover
  4. IBM ThinkPad T43 Screen Replacement: paso 4, imagen 1 de 1
    • Remove the two screws located near the bottom middle of the screen
  5. IBM ThinkPad T43 Screen Replacement: paso 5, imagen 1 de 3 IBM ThinkPad T43 Screen Replacement: paso 5, imagen 2 de 3 IBM ThinkPad T43 Screen Replacement: paso 5, imagen 3 de 3
    • Flip over the green rectangular shaped board
    • Disconnect the screen from the rectangular board using your fingers or tweezers
  6. IBM ThinkPad T43 Screen Replacement: paso 6, imagen 1 de 1
    • Using "Flat metal spudger" lift up the screen from the bottom slowly until you see the ribbon cable
    • Detach the ribbon cable before lifting completely the screen
    • Now you be able to remove the screen
    • Because of how the ribbon cable is connected, it may detach when you lift the screen up
  7. IBM ThinkPad T43 Screen Replacement: paso 7, imagen 1 de 3 IBM ThinkPad T43 Screen Replacement: paso 7, imagen 2 de 3 IBM ThinkPad T43 Screen Replacement: paso 7, imagen 3 de 3
    • To replace the screen follow the next set of steps
    • Using your fingers or tweezers, pull out the light by placing them on the sides and lifting up
    • Insert the wide plug on the ribbon cable into the new screen and place back into the laptop.
    • Now if you follow these steps in reverse order, you will be able to finish replacing the screen
Conclusión
aLiX pIeRRe
Miembro Desde 03/19/18
855 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 26
Todo El Tiempo: 1,289
