Saltar al contenido principal
IBM ThinkPad T43 CD Drive Replacement
Qué necesitas
  1. IBM ThinkPad T43 CD Drive Replacement, CD Drive: paso 1, imagen 1 de 1
    • Start by having the right side of the laptop facing you.
    • The laptop can be open if you would like, but it can be done easier if it is closed.
  2. IBM ThinkPad T43 CD Drive Replacement: paso 2, imagen 1 de 1
    • Remove the screw to be able to use the CD drive unlock switch
  3. IBM ThinkPad T43 CD Drive Replacement: paso 3, imagen 1 de 1
    • Locate the switch on the right side of the CD Drive.
  4. IBM ThinkPad T43 CD Drive Replacement: paso 4, imagen 1 de 3 IBM ThinkPad T43 CD Drive Replacement: paso 4, imagen 2 de 3 IBM ThinkPad T43 CD Drive Replacement: paso 4, imagen 3 de 3
    • Place finger in between the switch and the bumper
    • Slide the switch to the right until the plastic tab ejects.
  5. IBM ThinkPad T43 CD Drive Replacement: paso 5, imagen 1 de 3 IBM ThinkPad T43 CD Drive Replacement: paso 5, imagen 2 de 3 IBM ThinkPad T43 CD Drive Replacement: paso 5, imagen 3 de 3
    • Place fingers on the plastic tab.
    • Pull on the tab until the CD Drive ejects.
    • The tab only comes out about an inch to inch and a half.
    • Do not try to pull the tab all the way out.
    • If after you have removed the CD Drive and the tab goes back in, it is alright. It does not affect the later process.
  6. IBM ThinkPad T43 CD Drive Replacement: paso 6, imagen 1 de 2 IBM ThinkPad T43 CD Drive Replacement: paso 6, imagen 2 de 2
    • Grab the end of the CD Drive and pulls straight out towards your body.
    • Be careful not to pull it out at an angle to not risk damage.
  7. IBM ThinkPad T43 CD Drive Replacement: paso 7, imagen 1 de 1
    • Now that you have successfully removed the CD Drive you can put in the new one.
    • Place the end of the new CD Drive in and slide in until it clicks.
    • If you are using slight force and it doesn't go in, it could be jammed. Just take it out and try again.
    • If you had not already, you can push back in the tab.
Conclusión
Una persona más ha completado esta guía.
aLiX pIeRRe
Miembro Desde 03/19/18
855 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 8
Ultimos 30 días: 23
Todo El Tiempo: 851
