Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Introducción
Removal of the Wi-Fi Card.
Partes
No se especificaron partes.
  1. Unscrew the 20 Phillips screws on the underside of the T42.
    • Unscrew the 20 Phillips screws on the underside of the T42.
    • For ease of reassembly, keep your screws organized.
  2. Unscrew the 2 Phillips screws on both sides of the T42's rear.
    • Unscrew the 2 Phillips screws on both sides of the T42's rear.
  3. Flip the laptop over and open the screen.
    • Flip the laptop over and open the screen.
    • The bezel and keyboard will be loose, be careful.
  4. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together. Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  6. To remove Wi-Fi card, first disconnect both display wires on the top right.
    • To remove Wi-Fi card, first disconnect both display wires on the top right.
  7. Then slide both of the metal pieces holding it down outwards, and it will pop up.
    • Then slide both of the metal pieces holding it down outwards, and it will pop up.
  8. Carefully pull it out.
    • Carefully pull it out.
Conclusión
2 personas más completaron esta guía.
Kevin Rehm
Miembro Desde 19/04/10
394 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 29-76, Johann Spring 2010 Miembro de Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Miembros
30 Guías creadas
Get the HMM for the laptop! On a few of these, I have had to just pull out the internal wi-fi card, and use a USB wi-fi adapter.
Martin Campbell - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 27
Todo El Tiempo: 12,715
