Introducción
This guide will demonstrate the removal and replacement procedures for an IBM ThinkPad T42 Modem Daughter Board.
Qué necesitas
Use a Phillips #0 screwdriver to remove the twenty screws on the underside of the T42.
Remove the four Phillips screws located on either side of the rear of the T42 (there are two on each end.)
Flip the laptop over and open the screen to access the keyboard and trackpad.
Starting from the bottom right, carefully remove off the bezel. Use a spudger or flat head screwdriver if needed.
The cables are routed through different components for organization, carefully disconnect them, unwrap them and pull the card free.
2 personas más completaron esta guía.
