Introducción
The Mini-PCI port can be accessed easily after removing the rear cover
Qué necesitas
Use a Phillips #0 screwdriver to remove the twenty screws on the underside of the T42.
Remove the four Phillips screws located on either side of the rear of the T42 (there are two on each end.)
Flip the laptop over and open the screen to access the keyboard and trackpad.
Carefully disconnect it from the motherboard and pull it out of the device.
Una persona más ha completado esta guía.
