Saltar al contenido principal
IBM ThinkPad T42 Fan Replacement
Qué necesitas
  1. IBM ThinkPad T42 Fan Replacement, Bottom cover: paso 1, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove the twenty screws on the underside of the T42.
  2. IBM ThinkPad T42 Fan Replacement, Rear screws: paso 2, imagen 1 de 1
    • Remove the four Phillips screws located on either side of the rear of the T42 (there are two on each end.)
  3. IBM ThinkPad T42 Fan Replacement, Keyboard and Trackpad: paso 3, imagen 1 de 1
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Fan Replacement: paso 4, imagen 1 de 2 IBM ThinkPad T42 Fan Replacement: paso 4, imagen 2 de 2
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. IBM ThinkPad T42 Fan Replacement, Plastic Edge Cover: paso 5, imagen 1 de 2 IBM ThinkPad T42 Fan Replacement, Plastic Edge Cover: paso 5, imagen 2 de 2
    • Starting from the bottom right, carefully remove off the bezel. Use a spudger or flat head screwdriver if needed.
  6. IBM ThinkPad T42 Fan Replacement, Lower Bracket: paso 6, imagen 1 de 2 IBM ThinkPad T42 Fan Replacement, Lower Bracket: paso 6, imagen 2 de 2
    • Grasp the metal bracket to remove it from the device.
  7. IBM ThinkPad T42 Fan Replacement, Microphone cover: paso 7, imagen 1 de 1
    • Remove the rubber cover from the microphone.
  8. IBM ThinkPad T42 Fan Replacement, Fan Removal: paso 8, imagen 1 de 2 IBM ThinkPad T42 Fan Replacement, Fan Removal: paso 8, imagen 2 de 2
    • Using the Phillips #0 screwdriver, remove the three screws on the copper heatsink.
    • Separate the copper heatsink by pulling it upwards, in order to unplug the connector from the motherboard.
    • Due to the nature of old thermal paste, it might take some force to remove the heatsink.
Conclusión
8 personas más completaron esta guía.
Kevin Rehm
Miembro Desde 04/19/10
472 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 29-76, Johann Spring 2010 Miembro de Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Miembros
35 Guías creadas
2 comentarios
How about you just down the freely available Hardware Maintenance Manual (HMM) for the laptop. They are downloadable in PDF format, and very well done.
Martin Campbell - Contestar
It doesnt take this much, if you remove the palm rest and keyboard you can get it at an angle it slides straight out.
Tobyn Genn - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 30
Todo El Tiempo: 26,353
