Saltar al contenido principal
IBM ThinkPad T41 Wireless Network Card Replacement
Qué necesitas
  1. IBM ThinkPad T41 Wireless Network Card Replacement, Keyboard: paso 1, imagen 1 de 1
    • Close the screen and turn the closed laptop over.
    • Remove all 17 screws on the bottom of the computer.
    • The multiple colors (turquoise, red, blue, orange, yellow, and purple) are for organizational purposes, indicating different screws.
    • The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
  2. IBM ThinkPad T41 Wireless Network Card Replacement: paso 2, imagen 1 de 1
    • Remove the extra RAM cover, by lifting where the screw was and pulling out.
  3. IBM ThinkPad T41 Wireless Network Card Replacement: paso 3, imagen 1 de 1
    • Turn the laptop right side up and open the screen.
    • Lift the keyboard, using a spudger at the seam between the keyboard and trackpad.
    • Careful of the ribbon cable underneath, which may tear if the keyboard is lifted too vigorously.
  4. IBM ThinkPad T41 Wireless Network Card Replacement: paso 4, imagen 1 de 1
    • Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
    • Remove the keyboard.
  5. IBM ThinkPad T41 Wireless Network Card Replacement, Trackpad: paso 5, imagen 1 de 1
    • Close the laptop and turn it over.
    • Remove the five plastic stickers covering the screws on the front edge of the case.
    • In order to reuse the stickers, remove them carefully.
  6. IBM ThinkPad T41 Wireless Network Card Replacement: paso 6, imagen 1 de 1
    • Unscrew the five screws that were hidden by the stickers.
  7. IBM ThinkPad T41 Wireless Network Card Replacement: paso 7, imagen 1 de 1
    • Turn the computer right side up and open the screen.
    • Lift the trackpad assembly by placing hands on both edges and then pull towards you till it is free of the case.
    • Be careful of the ribbon cable underneath. It may tear if the trackpad is pulled too vigorously.
  8. IBM ThinkPad T41 Wireless Network Card Replacement: paso 8, imagen 1 de 1
    • Unplug the trackpad’s ribbon cable by pulling on the white plastic tab.
  9. IBM ThinkPad T41 Wireless Network Card Replacement, Wireless Network Card: paso 9, imagen 1 de 1
    • Pull off the one black and one white coaxial cables by lifting the tabs labeled main and aux (for auxiliary).
  10. IBM ThinkPad T41 Wireless Network Card Replacement: paso 10, imagen 1 de 1
    • Push apart the retaining clips.
    • Note: The card should pop up a little bit.
  11. IBM ThinkPad T41 Wireless Network Card Replacement: paso 11, imagen 1 de 1
    • Pull the wireless network card out.
Conclusión
10 personas más completaron esta guía.
Equipo
Cal Poly, Team 7-8, Maness Spring 2010 Miembro de Cal Poly, Team 7-8, Maness Spring 2010
CPSU-MANESS-S10S7G8
Miembros de 4
29 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 32,692
