Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
This simple repair guide will aid you in taking apart your IBM ThinkPad T41 laptop to reach and replace its keyboard.
Partes
No se especificaron partes.
  1. Close the screen and turn the closed laptop over.
    • Close the screen and turn the closed laptop over.
    • Remove all 17 screws on the bottom of the computer.
    • The multiple colors (turquoise, red, blue, orange, yellow, and purple) are for organizational purposes, indicating different screws.
    • The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
  2. Remove the extra RAM cover, by lifting where the screw was and pulling out.
    • Remove the extra RAM cover, by lifting where the screw was and pulling out.
  3. Turn the laptop right side up and open the screen.
    • Turn the laptop right side up and open the screen.
    • Lift the keyboard, using a spudger at the seam between the keyboard and trackpad.
    • Careful of the ribbon cable underneath, which may tear if the keyboard is lifted too vigorously.
  4. Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
    • Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
    • Remove the keyboard.
Conclusión
3 personas más completaron esta guía.
Equipo
Cal Poly, Team 7-8, Maness Spring 2010 Miembro de Cal Poly, Team 7-8, Maness Spring 2010
CPSU-MANESS-S10S7G8
4 Miembros
26 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 7,967
