Saltar al contenido principal
IBM ThinkPad T30 Wireless Card Replacement
Qué necesitas
  1. IBM ThinkPad T30 Wireless Card Replacement, Battery: paso 1, imagen 1 de 3 IBM ThinkPad T30 Wireless Card Replacement, Battery: paso 1, imagen 2 de 3 IBM ThinkPad T30 Wireless Card Replacement, Battery: paso 1, imagen 3 de 3
    • Make sure the ThinkPad is off and the power supply is unplugged.
    • Flip the ThinkPad upside down with the bottom facing you.
    • Slide the latch to the right into the unlock position.
    • While holding the latch in the unlock position, lift the battery out with your other hand.
  2. IBM ThinkPad T30 Wireless Card Replacement, Wireless Card: paso 2, imagen 1 de 3 IBM ThinkPad T30 Wireless Card Replacement, Wireless Card: paso 2, imagen 2 de 3 IBM ThinkPad T30 Wireless Card Replacement, Wireless Card: paso 2, imagen 3 de 3
    • Focus on the panel at the center of the Thinkpad.
    • Unscrew the three 4mm Phillips #0 screws that bind the panel cover to the Thinkpad.
    • Lift the panel from the right edge and remove the panel.
  3. IBM ThinkPad T30 Wireless Card Replacement: paso 3, imagen 1 de 3 IBM ThinkPad T30 Wireless Card Replacement: paso 3, imagen 2 de 3 IBM ThinkPad T30 Wireless Card Replacement: paso 3, imagen 3 de 3
    • Before removing the wireless card, identify the three wires that need to be removed.
    • The first two wires that are on the bottom right can be easily unplugged with your fingers by pulling on the white label that comes with the wire.
    • For the last wire on the center right, use a plastic opening tool to pry out the wire.
  4. IBM ThinkPad T30 Wireless Card Replacement: paso 4, imagen 1 de 3 IBM ThinkPad T30 Wireless Card Replacement: paso 4, imagen 2 de 3 IBM ThinkPad T30 Wireless Card Replacement: paso 4, imagen 3 de 3
    • Use the plastic opening tool to pry the hinges on the side of the wireless card. These hinges hold the wireless card in place.
    • The wireless card will pop up at an angle, and can then be easily pulled out.
    • When reinserting a new wireless card, insert the card at the angle that it popped out. Then simply push the card down to lock it back into the hatch.
Conclusión
2 personas más completaron esta guía.
Alex Kost
Miembro Desde 10/05/12
271 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 3-20, Amido Fall 2012 Miembro de Cal Poly, Team 3-20, Amido Fall 2012
CPSU-AMIDO-F12S3G20
3 Miembros
16 Guías creadas
Un comentario
I f i take out this component will the computer act normally The computer has a car diagnostic program installed as an after thought as i wish to be normal computer Do i just remove and ever thing okay thanks Terry
Terry Dollery - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 24
Todo El Tiempo: 5,297
