Introducción
Use this guide to replace your processor.
Partes
No se especificaron partes.
Flip the ThinkPad upside down with the bottom facing you.
Slide the latch on the underside of the ThinkPad to the right into the unlock position.
While holding the latch in the unlock position, lift the battery out with your other hand.
Begin by removing the two black 16 mm Phillips #0 screws. The screws can be identified by the two notches next to each screw. One (marked in red) is near the battery lock and the other (not pictured) is next to the Wi-Fi cover.
Push up the bottom of the keyboard by poking your finger through the hole to the right of the yellow bios battery. You will feel slight resistance.
To remove the processor, set the dial on the processor socket to unlock using a small screwdriver
Unscrew until processor looks like it "lifts" a little.
4 personas más completaron esta guía.
