Saltar al contenido principal
IBM ThinkPad R40 Fan Replacement
Qué necesitas
  1. IBM ThinkPad R40 Fan Replacement, Fan: paso 1, imagen 1 de 1
    • Remove the screws shown. These screws are connected to the keyboard.
  2. IBM ThinkPad R40 Fan Replacement: paso 2, imagen 1 de 1
    • Take the spudger tool, go around the edges of the oranges boxes shown, and pop off those two sections. Then, go around the edges of the keyboard, and it should slide off.
  3. IBM ThinkPad R40 Fan Replacement: paso 3, imagen 1 de 2 IBM ThinkPad R40 Fan Replacement: paso 3, imagen 2 de 2
    • Lift and move keyboard aside to get to screws. Try not to remove the attached ribbon.
    • Remove the screws shown. These screws will allow you to loosen the fan. Be careful since there is still another part connected.
  4. IBM ThinkPad R40 Fan Replacement: paso 4, imagen 1 de 1
    • Carefully unplug the highlighted part, and your fan should come straight out.
  5. IBM ThinkPad R40 Fan Replacement: paso 5, imagen 1 de 1
    • The section in blue is where your new fan will go.
Conclusión
5 personas más completaron esta guía.
Aaron
Miembro Desde 03/12/14
134 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 3
Ultimos 30 días: 20
Todo El Tiempo: 2,874
