Saltar al contenido principal
IBM ThinkPad A31 Keyboard Replacement
Qué necesitas
  1. IBM ThinkPad A31 Keyboard Replacement, Battery: paso 1, imagen 1 de 2 IBM ThinkPad A31 Keyboard Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the ThinkPad over so that it is upside down.
    • Push latch switch to the left.
    • Gently lift the battery out and away from the ThinkPad
    • You have to hold the latch to the left while you remove the battery. Simply pushing once will not unlock the battery
  2. IBM ThinkPad A31 Keyboard Replacement, Keyboard: paso 2, imagen 1 de 3 IBM ThinkPad A31 Keyboard Replacement, Keyboard: paso 2, imagen 2 de 3 IBM ThinkPad A31 Keyboard Replacement, Keyboard: paso 2, imagen 3 de 3
    • The sticker is to keep the warranty on the laptop so once removed the warranty is void
    • Peel the sticker and remove the 15mm screw
    • Remove all 6 of the 16mm screws
  3. IBM ThinkPad A31 Keyboard Replacement: paso 3, imagen 1 de 2 IBM ThinkPad A31 Keyboard Replacement: paso 3, imagen 2 de 2
    • use a prying tool and insert it on the cracks on the sides of the keyboard and lift gently until you here a click
    • repeat this step on all sides of the keyboard until the keyboard is completely detached from the laptop
  4. IBM ThinkPad A31 Keyboard Replacement: paso 4, imagen 1 de 3 IBM ThinkPad A31 Keyboard Replacement: paso 4, imagen 2 de 3 IBM ThinkPad A31 Keyboard Replacement: paso 4, imagen 3 de 3
    • Lift the keyboard and remove the keyboard ribbon cable from the laptop
Conclusión
2 personas más completaron esta guía.
Matheus
Miembro Desde 03/19/18
128 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 434
