Saltar al contenido principal
IBM ThinkPad A31 Display Replacement
Qué necesitas
  1. IBM ThinkPad A31 Display Replacement, Keyboard: paso 1, imagen 1 de 3 IBM ThinkPad A31 Display Replacement, Keyboard: paso 1, imagen 2 de 3 IBM ThinkPad A31 Display Replacement, Keyboard: paso 1, imagen 3 de 3
    • The sticker is to keep the warranty on the laptop so once removed the warranty is void
    • Peel the sticker and remove the 15mm screw
    • Remove all 6 of the 16mm screws
  2. IBM ThinkPad A31 Display Replacement: paso 2, imagen 1 de 2 IBM ThinkPad A31 Display Replacement: paso 2, imagen 2 de 2
    • use a prying tool and insert it on the cracks on the sides of the keyboard and lift gently until you here a click
    • repeat this step on all sides of the keyboard until the keyboard is completely detached from the laptop
  3. IBM ThinkPad A31 Display Replacement: paso 3, imagen 1 de 3 IBM ThinkPad A31 Display Replacement: paso 3, imagen 2 de 3 IBM ThinkPad A31 Display Replacement: paso 3, imagen 3 de 3
    • Lift the keyboard and remove the keyboard ribbon cable from the laptop
  4. IBM ThinkPad A31 Display Replacement, Display: paso 4, imagen 1 de 2 IBM ThinkPad A31 Display Replacement, Display: paso 4, imagen 2 de 2
    • Remove the one 21mm screw
    • Remove the 6mm screw
  5. IBM ThinkPad A31 Display Replacement: paso 5, imagen 1 de 2 IBM ThinkPad A31 Display Replacement: paso 5, imagen 2 de 2
    • Take the tool and run it under the black case.
  6. IBM ThinkPad A31 Display Replacement: paso 6, imagen 1 de 3 IBM ThinkPad A31 Display Replacement: paso 6, imagen 2 de 3 IBM ThinkPad A31 Display Replacement: paso 6, imagen 3 de 3
    • Unscrew the 2 (17mm) screws
    • Unscrew the 6mm screw
  7. IBM ThinkPad A31 Display Replacement: paso 7, imagen 1 de 2 IBM ThinkPad A31 Display Replacement: paso 7, imagen 2 de 2
    • Gently disconnect the white display ribbon cable
    • Pulling on the ribbon cable too hard could result in worse or faulty connection.
  8. IBM ThinkPad A31 Display Replacement: paso 8, imagen 1 de 3 IBM ThinkPad A31 Display Replacement: paso 8, imagen 2 de 3 IBM ThinkPad A31 Display Replacement: paso 8, imagen 3 de 3
    • Unscrew 4 (6mm) screws
    • Lift screen straight up
    • If not lifted straight up the screen could get damaged
Conclusión
Sean Tocci
Miembro Desde 03/19/18
293 Reputación
2 Guías creadas
Equipo
Un comentario
i have that but display is
not work
Ahmed Elwy - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 10
Todo El Tiempo: 484
