Saltar al contenido principal
IBM ThinkPad A31 CPU Replacement
Qué necesitas
  1. IBM ThinkPad A31 CPU Replacement, Hard Drive: paso 1, imagen 1 de 3 IBM ThinkPad A31 CPU Replacement, Hard Drive: paso 1, imagen 2 de 3 IBM ThinkPad A31 CPU Replacement, Hard Drive: paso 1, imagen 3 de 3
    • Remove the 6mm screw
    • Pull out the hard drive
    • The hard drive might be a little tough to pull out
  2. IBM ThinkPad A31 CPU Replacement, Keyboard: paso 2, imagen 1 de 3 IBM ThinkPad A31 CPU Replacement, Keyboard: paso 2, imagen 2 de 3 IBM ThinkPad A31 CPU Replacement, Keyboard: paso 2, imagen 3 de 3
    • The sticker is to keep the warranty on the laptop so once removed the warranty is void
    • Peel the sticker and remove the 15mm screw
    • Remove all 6 of the 16mm screws
  3. IBM ThinkPad A31 CPU Replacement: paso 3, imagen 1 de 2 IBM ThinkPad A31 CPU Replacement: paso 3, imagen 2 de 2
    • use a prying tool and insert it on the cracks on the sides of the keyboard and lift gently until you here a click
    • repeat this step on all sides of the keyboard until the keyboard is completely detached from the laptop
  4. IBM ThinkPad A31 CPU Replacement: paso 4, imagen 1 de 3 IBM ThinkPad A31 CPU Replacement: paso 4, imagen 2 de 3 IBM ThinkPad A31 CPU Replacement: paso 4, imagen 3 de 3
    • Lift the keyboard and remove the keyboard ribbon cable from the laptop
  5. IBM ThinkPad A31 CPU Replacement, Display: paso 5, imagen 1 de 2 IBM ThinkPad A31 CPU Replacement, Display: paso 5, imagen 2 de 2
    • Remove the one 21mm screw
  6. IBM ThinkPad A31 CPU Replacement: paso 6, imagen 1 de 2 IBM ThinkPad A31 CPU Replacement: paso 6, imagen 2 de 2
    • Take the tool and run it under the black case.
  7. IBM ThinkPad A31 CPU Replacement: paso 7, imagen 1 de 3 IBM ThinkPad A31 CPU Replacement: paso 7, imagen 2 de 3 IBM ThinkPad A31 CPU Replacement: paso 7, imagen 3 de 3
    • Unscrew the 2 (17mm) screws
    • Unscrew the 6mm screw
  8. IBM ThinkPad A31 CPU Replacement: paso 8, imagen 1 de 2 IBM ThinkPad A31 CPU Replacement: paso 8, imagen 2 de 2
    • Gently disconnect the white display ribbon cable
    • Pulling on the ribbon cable too hard could result in worse or faulty connection.
  9. IBM ThinkPad A31 CPU Replacement: paso 9, imagen 1 de 3 IBM ThinkPad A31 CPU Replacement: paso 9, imagen 2 de 3 IBM ThinkPad A31 CPU Replacement: paso 9, imagen 3 de 3
    • Unscrew 4 (6mm) screws
    • Lift screen straight up
    • If not lifted straight up the screen could get damaged
  10. IBM ThinkPad A31 CPU Replacement, Battery: paso 10, imagen 1 de 2 IBM ThinkPad A31 CPU Replacement, Battery: paso 10, imagen 2 de 2
    • Flip the ThinkPad over so that it is upside down.
    • Push latch switch to the left.
    • Gently lift the battery out and away from the ThinkPad
    • You have to hold the latch to the left while you remove the battery. Simply pushing once will not unlock the battery
  11. IBM ThinkPad A31 CPU Replacement, CPU: paso 11, imagen 1 de 3 IBM ThinkPad A31 CPU Replacement, CPU: paso 11, imagen 2 de 3 IBM ThinkPad A31 CPU Replacement, CPU: paso 11, imagen 3 de 3
    • LIft the bracket out
  12. IBM ThinkPad A31 CPU Replacement: paso 12, imagen 1 de 3 IBM ThinkPad A31 CPU Replacement: paso 12, imagen 2 de 3 IBM ThinkPad A31 CPU Replacement: paso 12, imagen 3 de 3
    • Remove one 6mm screw
    • Remove 3 18mm screws
    • Take off the bracket on the CPU fan
  13. IBM ThinkPad A31 CPU Replacement: paso 13, imagen 1 de 3 IBM ThinkPad A31 CPU Replacement: paso 13, imagen 2 de 3 IBM ThinkPad A31 CPU Replacement: paso 13, imagen 3 de 3
    • Lift the CPU fan
    • Pull out the cable attached to the motherboard
  14. IBM ThinkPad A31 CPU Replacement: paso 14, imagen 1 de 2 IBM ThinkPad A31 CPU Replacement: paso 14, imagen 2 de 2
    • Turn the locking screw to unlock with the flat head screwdriver
    • LIft the CPU out
Conclusión
Una persona más ha completado esta guía.
Thomas Stone
Miembro Desde 03/19/18
235 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 13
Todo El Tiempo: 938
