Saltar al contenido principal
IBM ThinkPad 600E Keyboard Replacement
Qué necesitas
  1. IBM ThinkPad 600E Keyboard Replacement, Battery: paso 1, imagen 1 de 3 IBM ThinkPad 600E Keyboard Replacement, Battery: paso 1, imagen 2 de 3 IBM ThinkPad 600E Keyboard Replacement, Battery: paso 1, imagen 3 de 3
    • Flip the laptop over and find the battery latch.
  2. IBM ThinkPad 600E Keyboard Replacement: paso 2, imagen 1 de 1
    • Move the latch to the side with the unlocked symbol.
  3. IBM ThinkPad 600E Keyboard Replacement: paso 3, imagen 1 de 3 IBM ThinkPad 600E Keyboard Replacement: paso 3, imagen 2 de 3 IBM ThinkPad 600E Keyboard Replacement: paso 3, imagen 3 de 3
    • Pry the battery out using your fingers.
  4. IBM ThinkPad 600E Keyboard Replacement, Keyboard: paso 4, imagen 1 de 3 IBM ThinkPad 600E Keyboard Replacement, Keyboard: paso 4, imagen 2 de 3 IBM ThinkPad 600E Keyboard Replacement, Keyboard: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Anti-Static Wrist Strap
    $7.95
    Comprar
    • Use an antistatic wrist strap to avoid the risk of electric shock.
    • Unscrew the coin screw for the hard drive using a coin. Pry off the HDD cover.
    • It is easier to remove the coin screw using a thicker coin, such as a nickel.
  5. IBM ThinkPad 600E Keyboard Replacement: paso 5, imagen 1 de 3 IBM ThinkPad 600E Keyboard Replacement: paso 5, imagen 2 de 3 IBM ThinkPad 600E Keyboard Replacement: paso 5, imagen 3 de 3
    • Unlock the highlighted latch and pull the disk drive out.
    • Remove the disk drive.
  6. IBM ThinkPad 600E Keyboard Replacement: paso 6, imagen 1 de 3 IBM ThinkPad 600E Keyboard Replacement: paso 6, imagen 2 de 3 IBM ThinkPad 600E Keyboard Replacement: paso 6, imagen 3 de 3
    • Most of the screws have a small, plastic covering attached with an adhesive. Use the metal spudger to pry it off. Make sure to note which screw came from which hole.
    • Four 18mm long M2.5 screws
    • Two 16mm long M2.5 screws
    • One 4.5mm long M2.5 screws
    • Four 3mm long M2.5 screws
  7. IBM ThinkPad 600E Keyboard Replacement: paso 7, imagen 1 de 2 IBM ThinkPad 600E Keyboard Replacement: paso 7, imagen 2 de 2
    • Open the laptop all the way until it is flat.
    • Take the black circle off and remove the screw.
  8. IBM ThinkPad 600E Keyboard Replacement: paso 8, imagen 1 de 3 IBM ThinkPad 600E Keyboard Replacement: paso 8, imagen 2 de 3 IBM ThinkPad 600E Keyboard Replacement: paso 8, imagen 3 de 3
    • Pry the keyboard case up from the bottom and gently pry it up from all other edges.
    • Use caution when opening the case, as there are two ribbon cables attached to the keyboard case.
  9. IBM ThinkPad 600E Keyboard Replacement: paso 9, imagen 1 de 3 IBM ThinkPad 600E Keyboard Replacement: paso 9, imagen 2 de 3 IBM ThinkPad 600E Keyboard Replacement: paso 9, imagen 3 de 3
    • Pry the connectors of the ribbon cables off slowly, lifting straight up. Wiggle gently side to side if necessary.
Conclusión
3 personas más completaron esta guía.
Kevin Nguyen
Miembro Desde 10/04/16
722 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 1-4, Nance Fall 2016 Miembro de USF Tampa, Team 1-4, Nance Fall 2016
USFT-NANCE-F16S1G4
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 22
Todo El Tiempo: 1,824
