Saltar al contenido principal
IBM ThinkPad 600E Hard Drive Disk Replacement
Qué necesitas
  1. IBM ThinkPad 600E Hard Drive Disk Replacement, Battery: paso 1, imagen 1 de 3 IBM ThinkPad 600E Hard Drive Disk Replacement, Battery: paso 1, imagen 2 de 3 IBM ThinkPad 600E Hard Drive Disk Replacement, Battery: paso 1, imagen 3 de 3
    • Flip the laptop over and find the battery latch.
  2. IBM ThinkPad 600E Hard Drive Disk Replacement: paso 2, imagen 1 de 1
    • Move the latch to the side with the unlocked symbol.
  3. IBM ThinkPad 600E Hard Drive Disk Replacement: paso 3, imagen 1 de 3 IBM ThinkPad 600E Hard Drive Disk Replacement: paso 3, imagen 2 de 3 IBM ThinkPad 600E Hard Drive Disk Replacement: paso 3, imagen 3 de 3
    • Pry the battery out using your fingers.
  4. IBM ThinkPad 600E Hard Drive Disk Replacement, Hard Drive Disk: paso 4, imagen 1 de 1
    • Put on the anti-static wrist trap and clip it to a large metal object.
    • If you do not have an anti-static wristband, make sure to touch a large metal object to ground yourself before beginning to work on your replacement. Occasionally touch the metal object.
  5. IBM ThinkPad 600E Hard Drive Disk Replacement: paso 5, imagen 1 de 3 IBM ThinkPad 600E Hard Drive Disk Replacement: paso 5, imagen 2 de 3 IBM ThinkPad 600E Hard Drive Disk Replacement: paso 5, imagen 3 de 3
    • Using a coin, remove the coin screw by turning counterclockwise.
    • It's best to use a thicker coin, such as a nickel.
  6. IBM ThinkPad 600E Hard Drive Disk Replacement: paso 6, imagen 1 de 1
    • Using a plastic spudger, pry off the plastic cover by pulling it out.
  7. IBM ThinkPad 600E Hard Drive Disk Replacement: paso 7, imagen 1 de 3 IBM ThinkPad 600E Hard Drive Disk Replacement: paso 7, imagen 2 de 3 IBM ThinkPad 600E Hard Drive Disk Replacement: paso 7, imagen 3 de 3
    • Utilizing your fingers, untuck the tab and pull to remove the hard drive.
  8. IBM ThinkPad 600E Hard Drive Disk Replacement: paso 8, imagen 1 de 3 IBM ThinkPad 600E Hard Drive Disk Replacement: paso 8, imagen 2 de 3 IBM ThinkPad 600E Hard Drive Disk Replacement: paso 8, imagen 3 de 3
    • Using a screwdriver, remove the screws by turning them counterclockwise to remove the bracket.
    • four 3mm PH0 screws
    • The metal bracket is still attached with a weak adhesive tape, gently pry it off with a spudger.
  9. IBM ThinkPad 600E Hard Drive Disk Replacement: paso 9, imagen 1 de 2 IBM ThinkPad 600E Hard Drive Disk Replacement: paso 9, imagen 2 de 2
    • The top plastic piece is adhered with a weak adhesive. Gently pry it off with a spudger.
Conclusión
3 personas más completaron esta guía.
Kevin Nguyen
Miembro Desde 10/04/16
722 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 1-4, Nance Fall 2016 Miembro de USF Tampa, Team 1-4, Nance Fall 2016
USFT-NANCE-F16S1G4
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 27
Todo El Tiempo: 3,190
