Introducción
This guide will show you how to replace your display from your laptop. You would need to replace it if you break your display.
Qué necesitas
Unscrew the coin screw for the hard drive using a coin. Pry off the HDD cover.
Remove the plastic part attached to the bottom of the screen.
Gently pull it from one side and then from another.
Una persona más ha completado esta guía.
