Saltar al contenido principal
IBM ThinkPad 560z Keyboard Cover Replacement
Qué necesitas
  1. IBM ThinkPad 560z Keyboard Cover Replacement, Upper Case: paso 1, imagen 1 de 1
    • Remove the 7 mm Phillips #0 screws.
    • Remove the 10 mm Phillips #0 screws.
    • Remove the 14 mm Phillips #0 screw.
  2. IBM ThinkPad 560z Keyboard Cover Replacement: paso 2, imagen 1 de 2 IBM ThinkPad 560z Keyboard Cover Replacement: paso 2, imagen 2 de 2
    • Open the flap on the left hand side.
  3. IBM ThinkPad 560z Keyboard Cover Replacement: paso 3, imagen 1 de 2 IBM ThinkPad 560z Keyboard Cover Replacement: paso 3, imagen 2 de 2
    • Insert the plastic opening tools between the right and left sides of the latch.
    • Pry the right side of the latch, and then pry the left side to detach the laptop's cover.
  4. IBM ThinkPad 560z Keyboard Cover Replacement: paso 4, imagen 1 de 2 IBM ThinkPad 560z Keyboard Cover Replacement: paso 4, imagen 2 de 2
    • Open the flap on the right side.
  5. IBM ThinkPad 560z Keyboard Cover Replacement: paso 5, imagen 1 de 1
    • Insert the plastic opening tools towards the right side of the latch.
    • Gently pry the right side out to release the top cover.
  6. IBM ThinkPad 560z Keyboard Cover Replacement: paso 6, imagen 1 de 2 IBM ThinkPad 560z Keyboard Cover Replacement: paso 6, imagen 2 de 2
    • Lift the keyboard slowly.
    • A cable connects the keyboard to the motherboard. If you are not careful, you will damage the cable.
  7. IBM ThinkPad 560z Keyboard Cover Replacement: paso 7, imagen 1 de 1
    • Use your fingers or a spudger to detach the connector.
  8. IBM ThinkPad 560z Keyboard Cover Replacement: paso 8, imagen 1 de 2 IBM ThinkPad 560z Keyboard Cover Replacement: paso 8, imagen 2 de 2
    • Carefully lift and remove the keyboard.
Conclusión
Equipo
Cal Poly, Team 26-27, Regan Spring 2010 Miembro de Cal Poly, Team 26-27, Regan Spring 2010
CPSU-REGAN-S10S26G27
3 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 1,800
