Saltar al contenido principal
Hytera TC-580 Speaker Replacement
Qué necesitas
  1. Hytera TC-580 Speaker Replacement, Battery: paso 1, imagen 1 de 2 Hytera TC-580 Speaker Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the two 10mm Phillips #0 from the belt clip.
  2. Hytera TC-580 Speaker Replacement: paso 2, imagen 1 de 2 Hytera TC-580 Speaker Replacement: paso 2, imagen 2 de 2
    • Push in the release button and pull up on the battery to remove.
  3. Hytera TC-580 Speaker Replacement, Antenna: paso 3, imagen 1 de 1
    • Twist antenna counter-clockwise and set damaged antenna aside.
  4. Hytera TC-580 Speaker Replacement, Keypad: paso 4, imagen 1 de 1
    • Remove the volume knob by firmly lifting up on both sides of it.
  5. Hytera TC-580 Speaker Replacement: paso 5, imagen 1 de 1
    • Remove the orange o-ring around volume knob using tweezers.
  6. Hytera TC-580 Speaker Replacement: paso 6, imagen 1 de 1
    • Remove grey nut from base of volume knob by turning it counterclockwise with a set of tweezers.
  7. Hytera TC-580 Speaker Replacement: paso 7, imagen 1 de 1
    • Remove the brass washer from the base of the antenna slot by turning it counterclockwise with a set of tweezers.
  8. Hytera TC-580 Speaker Replacement: paso 8, imagen 1 de 2 Hytera TC-580 Speaker Replacement: paso 8, imagen 2 de 2
    • Remove the two 15mm T8 Torx screws from the base of the battery cavity.
  9. Hytera TC-580 Speaker Replacement: paso 9, imagen 1 de 1
    • Using a plastic opening tool, pry in between the plastic case and metal circuit board to remove the board.
  10. Hytera TC-580 Speaker Replacement: paso 10, imagen 1 de 1
    • Peel off the keypad by hand.
  11. Hytera TC-580 Speaker Replacement, Speaker: paso 11, imagen 1 de 3 Hytera TC-580 Speaker Replacement, Speaker: paso 11, imagen 2 de 3 Hytera TC-580 Speaker Replacement, Speaker: paso 11, imagen 3 de 3
    • Remove eleven 4mm Phillips #00 screws.
  12. Hytera TC-580 Speaker Replacement: paso 12, imagen 1 de 1
    • Apply a soldering iron to the solder joints to remove the two wires connecting the speaker to the circuit board.
Conclusión
Mohammed Chehab
Miembro Desde 02/14/18
88 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S3-G4, Nance Spring 2018 Miembro de USF Tampa, Team S3-G4, Nance Spring 2018
USFT-NANCE-S18S3G4
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 494
