Saltar al contenido principal
HyperX QuadCast S Mute Sensor Replacement
  1. HyperX QuadCast S Mute Sensor Replacement, Tap-To-Mute Sensor: paso 1, imagen 1 de 3 HyperX QuadCast S Mute Sensor Replacement, Tap-To-Mute Sensor: paso 1, imagen 2 de 3 HyperX QuadCast S Mute Sensor Replacement, Tap-To-Mute Sensor: paso 1, imagen 3 de 3
    • Set the microphone on a flat surface.
    • Pull each of the support bands upwards and off of the notches to release the microphone from its base.
    • There are four support bands in total, but it does not matter which band you choose to take off first.
  2. HyperX QuadCast S Mute Sensor Replacement: paso 2, imagen 1 de 3 HyperX QuadCast S Mute Sensor Replacement: paso 2, imagen 2 de 3 HyperX QuadCast S Mute Sensor Replacement: paso 2, imagen 3 de 3
    • Grab ahold of the tap-to-mute Sensor and pull it upwards in a clockwise motion.
    • Be careful not to damage the cable as you remove the top.
    • Once the tap-to-mute sensor detaches from the microphone, you will hear a small "pop."
  3. HyperX QuadCast S Mute Sensor Replacement: paso 3, imagen 1 de 3 HyperX QuadCast S Mute Sensor Replacement: paso 3, imagen 2 de 3 HyperX QuadCast S Mute Sensor Replacement: paso 3, imagen 3 de 3
    • Gently unplug the cable, and remove the tap to the Tap-To-Mute sensor from the microphone.
    • The square indicates the location of the cable. This is cable is very small and will require a bit of force to be unplugged.
Conclusión
Una persona más ha completado esta guía.
Nathan Arruda
Miembro Desde 10/25/22
711 Reputación
6 Guías creadas
Equipo
UMass Dartmouth, Team 4-1, Sinclaire Fall 2022 Miembro de UMass Dartmouth, Team 4-1, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G1
5 Miembros
9 Guías creadas
2 comentarios
Nice guide, but I've been unable to find a replacement.
Is the tap sensor from the Quadcast (the non-S version) compatible?
P S - Contestar
I believe it should be compatible. The S version should just be different with its illumination and USB charging so the tap-to-mute sensor should be the same. Unfortunately, it's hard to source replacement parts since hyperx does not sell them separately. I could only recommend buying a used hyperx microphone for cheap and scraping the parts for replacement. Hope that helps.
Nathan Arruda - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 9
Ultimos 7 días: 38
Ultimos 30 días: 151
Todo El Tiempo: 2,458
