Introducción
This guide will aid you in replacing (or cleaning) the Injector Nozzle, Injector Throat, and Injector Screen in a Hydrotech 89-series Control Valve used on water softeners and iron filters.
You may need to do this if your equipment is malfunctioning in the following ways:
- Not drawing brine correctly or efficiently
- Not drawing brine at all
- Sending water to the brine tank during the brine draw cycle
Qué necesitas
Locate the RED bypass knobs.
Using an allan key or a pair of pliers, turn the knobs so the stamped arrows are facing each other.
CAUTION: The bypass knobs may become detached, if this happens take note of the position of the knob and return the knob to that position and press down to reseat it.
Activate manual regeneration
After the valve is unlcoked, press the [MENU] button once more to bring up a menu prompt.
Repeatedly press the {DOWN] button until "Manual Regen" is selected.
Press Set
Use the [UP} arrow to select "Regen Now" and press {SET} to begin the regeneration process.
Press and hold any button for approximately 3 seconds to skip ahead, do this until the valve is in either BACKWASH or RINSE.
Wait until the time begins to count down to ensure it is has relieved pressure
Note: If you have a Downflow valve or are using this valve on a filter your first regeneration cycle will be BACKWASH, you won't need to skip ahead.
Note: The valve may take a couple of minutes to move between cycles, please be patient with it.
Removing the Injector Cover (A36)
Remove the two #2 Phillips screws (A4) from the injector cover (A36) and remove with your fingers.
REASSEMBLY
To reassemble, insert the injector throat, injector nozzle and injector screen in reverse order of removal.
Prior to reinstalling the Injector Cover (A36) and reinstalling the screws, apply a layer of silicone grease to the o-ring (A35), this will allow the o-ring to reseal to the valve body properly.
You have successfully replaced (or cleaned) the Injectors in your Hydrotech 89-series Control Valve.
You may now party on!
