Saltar al contenido principal
Husqvarna Viking Designer 1 Needle Replacement
Qué necesitas
  1. Husqvarna Viking Designer 1 Needle Replacement, Needle: paso 1, imagen 1 de 2 Husqvarna Viking Designer 1 Needle Replacement, Needle: paso 1, imagen 2 de 2
    • Remove the thread from the needle by pulling it out.
  2. Husqvarna Viking Designer 1 Needle Replacement: paso 2, imagen 1 de 3 Husqvarna Viking Designer 1 Needle Replacement: paso 2, imagen 2 de 3 Husqvarna Viking Designer 1 Needle Replacement: paso 2, imagen 3 de 3
    • Turn the knob counterclockwise to life up the needle.
    • Turning the knob clockwise can damage the machine.
  3. Husqvarna Viking Designer 1 Needle Replacement: paso 3, imagen 1 de 1
    • Place a sheet of paper under the foot. In the event that the needle falls out, this will prevent it from falling into the bobbin area.
  4. Husqvarna Viking Designer 1 Needle Replacement: paso 4, imagen 1 de 2 Husqvarna Viking Designer 1 Needle Replacement: paso 4, imagen 2 de 2
    • Hold onto the needle with one hand, and use a Singer #412381501 screwdriver to loosen the needle clamp screw (model: Viking #4125825-01) located next to the top of the needle with the other hand.
  5. Husqvarna Viking Designer 1 Needle Replacement: paso 5, imagen 1 de 1
    • Discard the broken or unwanted needle, and select a new one.
  6. Husqvarna Viking Designer 1 Needle Replacement: paso 6, imagen 1 de 2 Husqvarna Viking Designer 1 Needle Replacement: paso 6, imagen 2 de 2
    • Insert the new needle with the flat side facing away from you.
  7. Husqvarna Viking Designer 1 Needle Replacement: paso 7, imagen 1 de 1
    • Hold onto the needle with one hand, and use a Singer #412381501 screwdriver to tighten the needle clamp screw (model: Viking #4125825-01) with the other hand.
  8. Husqvarna Viking Designer 1 Needle Replacement: paso 8, imagen 1 de 1
    • Thread the needle. (See pages 8-10 from the link.)
    • You may now remove the sheet of paper and begin sewing!
Conclusión
Replacing the needle is a quick, easy task to complete, using the directions provided in this guide.
Una persona más ha completado esta guía.
Un comentario
Excellent illustration!!!
KO SAMUEL TAK SHUN - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 35
Todo El Tiempo: 1,318
