Introducción
This Fast fix is needed if your Husqvarna Trimmer is running irregular or is having trouble running. This normally means the carburetor needs to be replaced. Please allow the unit to cool down prior to attempting the repair to avoid burning yourself. Also wear safety glasses to prevent gas splashing in your eyes when disconnecting fuel lines.
Qué necesitas
Using your fingers, unscrew the air filter bolt and remove it from the filter cover.
2 personas más completaron esta guía.
