Introducción
If for any reason your Huntington GA41PS-RDS acoustic guitar string is broken, use this guide to replace it. The guide will teach you to replace any number of strings. Be careful when handling the strings, the pointed end if poked by can cause bleeding. Before using this guide identify all the strings that need to be replaced.
Qué necesitas
Place your guitar on a flat surface where you can easily identify the broken string.
Casi Terminas!
Conclusión
