Saltar al contenido principal
Huawei Watch Jewel Strap Replacement
Qué necesitas
  1. Huawei Watch Jewel Strap Replacement, Strap: paso 1, imagen 1 de 2 Huawei Watch Jewel Strap Replacement, Strap: paso 1, imagen 2 de 2
    • Begin by laying the watch on a flat, smooth surface.
    • This will prevent the watch screen from suffering damage.
    • Obtain a Flex Extension with a Size 1.0 mm flat-head. In the case of not having said tool, for this model of watch one can use the hands to replace the strap.
  2. Huawei Watch Jewel Strap Replacement: paso 2, imagen 1 de 2 Huawei Watch Jewel Strap Replacement: paso 2, imagen 2 de 2
    • Locate the two springs on the back of your watch.
    • The watch comes with two of these springs on each side of the back-face. These are used to release the straps from the body of the watch.
  3. Huawei Watch Jewel Strap Replacement: paso 3, imagen 1 de 3 Huawei Watch Jewel Strap Replacement: paso 3, imagen 2 de 3 Huawei Watch Jewel Strap Replacement: paso 3, imagen 3 de 3
    • Use the Flex Extension to push the spring to the right. This will release the strap from the watch head.
  4. Huawei Watch Jewel Strap Replacement: paso 4, imagen 1 de 1
    • Carefully pull the strap away from the watch.
  5. Huawei Watch Jewel Strap Replacement: paso 5, imagen 1 de 2 Huawei Watch Jewel Strap Replacement: paso 5, imagen 2 de 2
    • Repeat step 3, this time using the other strap.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 5-3, Passmore Spring 2017 Miembro de USF Tampa, Team 5-3, Passmore Spring 2017
USFT-PASSMORE-S17S5G3
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 842
